Galaxy rotational curves vs time
In summary: Aug 2015 (v1), last revised 26 Aug 2015 (v2))Comments: 16 pages, ApJ, acceptedSubjects: Astrophysics of Galaxies (astro-ph.GA)DOI: 10.3847/0004-637X/824/2/16Cite as: arXiv:1508.02612 [astro-ph.GA]This paper presents the first results of a study of the cosmological implications of the lens redshift distribution of strong lensing systems. The study is based on a sample of 66 lensing systems with a redshift range of 0.5<z<8.5. By using the
Daniel Dimov
Hello to everyone,
I'm trying to find some data about the relation between galaxy age and rotational curve... until now without success.
Are there any teams working on this? Are there any studies in this direction?
Thanks!
Astronomy news on Phys.org
Welcome to PF.
Radio observation of the hydrogen line from galaxies viewed side-on show two peaks due to the rate of rotation of the galaxy. From that the red shift of the galaxy as a whole can also be estimated.
Can you be more specific about what you need? and why you need it?
The interesting question is: do galaxies evolve to what we see nearby (more apparent mass than we can directly see) or they are like this from the beginning?
I understand that the current consensus is there is no evidence of any significant evolution in. Rotation. curve profiles or dark matter content. Of spiral galaxies.
I think your "." key is stuck.
I think he meant to use his comma - "," - key...
Actually, that wouldn't make any sense either. There is no reason for a "." OR a "," anywhere in that sentence.
Ah. I see he's not a native English speaker. That's probably the heart of the issue. @TEFLing your English Is WAY better than my Thai :smile:
Daniel Dimov said:
Hello to everyone,
Thanks!
This is an area of active study. Many teams of astronomers are actively trying to compare the oldest observable galaxies with modern galaxies.
Leading theories of galaxy formation tend to predict that "modern" looking galaxies should only begin to be visible later in time since the Big Bang than they are actually observed. This is called the "Impossible Early Galaxy problem." As explained in the linked article:
The Impossibly Early Galaxy Problem
Charles L. Steinhardt, Peter Capak, Dan Masters, Josh S. Speagle
(Submitted on 3 Jun 2015 (v1), last revised 8 Apr 2016 (this version, v2))
The current hierarchical merging paradigm and ΛCDM predict that the z∼4−8 universe should be a time in which the most massive galaxies are transitioning from their initial halo assembly to the later baryonic evolution seen in star-forming galaxies and quasars. However, no evidence of this transition has been found in many high redshift galaxy surveys including CFHTLS, CANDELS and SPLASH, the first studies to probe the high-mass end at these redshifts. Indeed, if halo mass to stellar mass ratios estimated at lower-redshift continue to z∼6−8, CANDELS and SPLASH report several orders of magnitude more M∼1012−13M⊙ halos than are possible to have formed by those redshifts, implying these massive galaxies formed impossibly early. We consider various systematics in the stellar synthesis models used to estimate physical parameters and possible galaxy formation scenarios in an effort to reconcile observation with theory. Although known uncertainties can greatly reduce the disparity between recent observations and cold dark matter merger simulations, even taking the most conservative view of the observations, there remains considerable tension with current theory.
Comments: 10 pages, ApJ, in press
DOI: 10.3847/0004-637X/824/1/21
Cite as: arXiv:1506.01377 [astro-ph.GA]
(or arXiv:1506.01377v2 [astro-ph.GA] for this version)
Likes alantheastronomer
"The Impossibly Early Galaxy Problem" seems to imply that the hierarchical merger model of galaxy formation doesn't work and needs to be abandoned as the process by which galaxies form. Apart from this, there's a practical reason why there are no measurements of rotation curves of galaxies in the early universe; you can only get rotation curves of galaxies which are nearly edge-on to the line of sight of the observer. This means that the galaxies you want to observe have very low surface brightness due to interference from dust lanes. On top of that, as you go to further distances, the angular size of the galaxies get smaller, you have less spatial resolution in order to determine velocity as a function of radius - and that's worse in the radio region. So these selection effects make it impractical to make the observations...It's too bad, because that's a very interesting question!
Likes ohwilleke and Baluncore
Another example of studies early galaxies, where as @alantheastronomer notes, properties other than rotation curves (such a velocity dispersion) are usually measured:
Implications of the lens redshift distribution of strong lensing systems: cosmological parameters and the global properties of early-type galaxies
Yu-Bo Ma, Shuo Cao, Jia Zhang, Shuaibo Geng, Yuting Liu, Tonghua Liu, Yu Pan
(Submitted on 28 Jan 2019)
In this paper, we assemble a well-defined sample of early-type gravitational lenses extracted from a large collection of 158 systems, and use the redshift distribution of galactic-scale lenses to test the standard cosmological model (ΛCDM) and the modified gravity theory (DGP). Two additional sub-samples are also included to account for possible selection effect introduced by the detectability of lens galaxies. Our results show that independent measurement of the matter density parameter (Ωm) could be expected from such strong lensing statistics. Based on future measurements of strong lensing systems from the forthcoming LSST survey, one can expect Ωm to be estimated at the precision of ΔΩm∼0.006, which provides a better constraint on Ωm than \textit{Planck} 2015 results. Moreover, use the lens redshift test is also used to constrain the characteristic velocity dispersion of the lensing galaxies, which is well consistent with that derived from the optical spectroscopic observations. A parameter fE is adopted to quantify the relation between the lensing-based velocity dispersion and the corresponding stellar value. Finally, the accumulation of detectable galactic lenses from future LSST survey would lead to more stringent fits of ΔfE∼10−3, which encourages us to test the global properties of early-type galaxies at much higher accuracy.
Comments: 12 pages, accepted for publication in The European Physical Journal C
Subjects: Cosmology and Nongalactic Astrophysics (astro-ph.CO)
Cite as: arXiv:1901.09737 [astro-ph.CO]
(or arXiv:1901.09737v1 [astro-ph.CO] for this version)
Related to Galaxy rotational curves vs time
1. How do galaxy rotational curves change over time?
The rotational curves of galaxies are determined by the distribution of mass within the galaxy. As galaxies evolve, the distribution of mass can change due to factors such as mergers with other galaxies, interactions with dark matter, and star formation. Therefore, the rotational curves of galaxies can change over time.
2. What causes the differences in rotational curves between galaxies?
The differences in rotational curves between galaxies can be attributed to the varying amounts of mass within each galaxy. Galaxies with more mass will have stronger gravitational forces, leading to steeper rotational curves. Additionally, the distribution of mass within a galaxy can also affect its rotational curve.
3. How do scientists measure galaxy rotational curves?
Scientists measure galaxy rotational curves by observing the Doppler shifts of light emitted by stars within the galaxy. As stars move towards or away from Earth, the wavelength of their emitted light changes, allowing scientists to determine their velocity. This information is then used to construct a rotational curve for the galaxy.
4. What can galaxy rotational curves tell us about dark matter?
Galaxy rotational curves have played a crucial role in the study of dark matter. The observed rotational curves of galaxies do not match the predictions based on the visible mass alone, indicating the presence of an invisible, massive substance such as dark matter. By studying the rotational curves of galaxies, scientists can gain insights into the distribution and properties of dark matter.
5. How does the shape of a galaxy affect its rotational curve?
The shape of a galaxy can affect its rotational curve because it determines the distribution of mass within the galaxy. For example, a galaxy with a more spherical shape will have a more symmetrical distribution of mass, leading to a flatter rotational curve. On the other hand, a galaxy with a more elongated shape will have a more asymmetrical distribution of mass, resulting in a steeper rotational curve.
