jbriggs444
2024 Award
- 13,334
- 8,010
It was too verbose. I was left wondering what the point was. The part about something moving backward, but not really but yes, moving backward relative to the train frame was very off-putting. Here is that passage:gionole said:@jbriggs444 So everything I said is correct ? Right ? Just to be sure.
There is no such thing as a "real sense". All motion is relative. There is no need to waffle. Pick a frame and describe the ball's motion in that frame. Don't handwave about other frames that you could have used but did not.gionole said:to me(observer in the train), while ball is dropping, it moves backward, but not in real sense, because while ball is in the air(dropping), train still accelerates, so it moves with increased speed, but ball in the air doesn't feel this increased speed.
Your conclusion was that:gionole said:Do you mind explaining what you mean here ?
But a conclusion about inertial frames has nothing to do with reasoning that involves accelerating frames. So your talk about accelerating frames was irrelevant.gionole said:So Landau’s argument that in all inertial frames, equation of motion of the same system takes the same form seems to be correct if my analysis is correct.
Reasoning that only addresses the ##x## component of position is one dimensional. You only reasoned about one dimension. So your reasoning was restricted to one dimensional inertial frames of reference that may be in relative motion in that single dimension.
You've dealt with the case of a single object in force-free motion as described in two different one dimensional inertial frames and reasoned that the same force law (no force) applies in both frames.
That is a weak basis on which to conclude that the principle of [Galilean] relativity holds good for all physical force laws and does so in three dimensions.
