Galilean transform and Lorentz transform questions
The discussion clarifies the application of the Galilean and Lorentz transforms in relation to moving and stationary observers. It confirms that the Galilean transform can determine Alice's position from Bob's perspective and vice versa, but does not apply when considering Bob as the moving observer with Alice stationary. Similarly, the Lorentz transform operates under the same principles, allowing for the conversion of coordinates between different rest frames. The conversation emphasizes that both transforms facilitate understanding the relationship between observers in motion. Additionally, there is a request for resources to practice problems related to Galilean transforms.
rgtr
I am just curious about the Galilean transform and the Lorentz Transform
## x = x'+vt ##
## x = gamma(x'+vt') ##
I have a quick question about the Galilean transform. If I have Alice running and Bob stationary. The Galilean transform will tell me the position of Alice from Bob's stationary position. Also if I have Alice's position which is moving it will tell me Bob's stationary position.
If I want Bob moving and Alice stationary that is not what the Galilean transform does. Is this correct?
I have not gotten to it yet but previously have read a little bit about the Lorentz transform for position the same logic applies as above.
If I want Bob moving and Alice stationary that is not what the Lorentz transform does. Is this correct?
No, it will not. It will tell you how the coordinates of an event in Alice and Bob’s rest frames relate to each other.
rgtr said:
Homework Statement:: I am just curious about the Galilean transform and the Lorentz Transform
Relevant Equations:: ## x = x'+vt ##
No. Both going back and forth between their rest frames are Galilean/Lorentz transformations (which depending on whether you do classical mechanics or special relativity).
Thanks for that clarification. Any idea where I could practice a few questions about Galilean transforms?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
