Galilean transformations x Galilean Group
In summary, Galilean transformations and the transformations of the Galilean group both involve rotations, but the latter is usually defined as transformations that leave Newton's second law invariant. Elementary treatments only consider motion along one spatial dimension and ignore the other two, while more sophisticated treatments allow for a more general set of transformations. The approach taken depends on the context and the audience's familiarity with group theory.
kent davidge
933
56
It seems that there is a difference between Galilean transformations and (the transformations of the) Galilean group, for one thing: rotations.
The former is usually defined as the transformations ##\{\vec{x'} = \vec x - \vec v t, \ t' = t \}##, where ##\vec v## is the primed frame velocity relative to the first frame. On the other hand, rotations are also a possibility in going from one inertial frame to another, and they seem to be included in the Galilean Group.
So when people refer to Galilean Transformations do they mean the transformations that leave Newtons second law invariant? And when they are considering all transformations that leave the second law covariant then they are talking about the Galilean group?
It depends on the context.
Elementary treatments generally consider only motion along one spatial dimension called ##x## (ignoring the other two completely or only mentioning ##y'=y##, ##z'=z## as afterthoughts subsequently ignored). In this case, the discussion is going to be limited to the subgroup of boosts. The author won't even mention that there is such a thing as a "Galilean Group" and that what they're doing is equivalent to considering a "subgroup" of that group; this approach has the pedagogical advantage of working for an audience that has never heard of group theory.
More sophisticated treatments will allow for the more general set of transformations, although will often adopt the simpler picture if no rotations are involved
You are expected to be able to figure out for yourself which kind of treatment you're dealing with.
Likes kent davidge
Related to Galilean transformations x Galilean Group
What are Galilean transformations and the Galilean Group?
Galilean transformations refer to the mathematical equations that describe the relationship between space and time in classical mechanics. The Galilean Group is a set of transformations that preserve the laws of physics in a non-accelerating reference frame.
What is the difference between Galilean transformations and Lorentz transformations?
Galilean transformations only apply to non-accelerating reference frames, while Lorentz transformations are used in special relativity to describe the relationship between space and time in all frames of reference.
How do Galilean transformations impact our understanding of motion?
Galilean transformations allow us to describe the motion of objects in classical mechanics, including their position, velocity, and acceleration, in different frames of reference. They also help us understand the principle of relativity, which states that the laws of physics are the same in all inertial frames of reference.
What are some real-world applications of Galilean transformations?
Galilean transformations have been used in various fields, including physics, engineering, and astronomy. They are used to calculate the motion of objects in everyday situations, such as the trajectory of a projectile, the motion of a pendulum, or the orbit of a planet.
Are Galilean transformations still relevant in modern physics?
While Galilean transformations are limited to non-accelerating reference frames, they are still relevant in many practical applications, such as in classical mechanics and engineering. However, they are not accurate in describing the behavior of objects moving at high speeds, which is where Lorentz transformations and special relativity come into play.
  • Classical Physics
  • Classical Physics
  • Classical Physics
