Ephant
- 147
- 2
9V DC can kill. Did you hear the story of this person who tried using multimeter to test resistance of his skin. He tried to thin his skin then the current of the multimeter probe got bigger and stopped his heart and he got killed.
So in electrode works in the skin where it is prep by abrading it with gel, the equipment must have utmost galvanic isolation.
I'd like to inquire about the different kinds of galvanic isolation.
Some use Opto-isolator to isolate the serial or USB wires. But here the chassis is still not protected, is it?
Then you have the ISO122 where the input signal is transmitted digitally across a high-voltage differential capacitive barrier. Is this safer than just isolating the serial or USB using opto-isolator?
https://www.ti.com/lit/ds/symlink/i...49383&ref_url=https%3A%2F%2Fwww.google.com%2F
Can you also use opto-isolator to isolate the electrodes or only the ISO122, and can the ISO122 be used on the serial or USB? Does it use different chip depending on where you want to put the isolation circuit?
Also isn't there a general commercial single channel differential isolation module where you insert the 3 electrode wires (2 differential plus ground/reference/common) and it has outputs where the 3 can be connected to any bioamplifier unit? Is this possible? Perhaps the safest of all as backup to any existing isolator in the main equipment?
