Tim?
- 2
what I'm doing. I'm trying to install copper-nickle brake lines but I'm trying to figure out what fitting to use. options are brass, steel, or stainless(which would fluctuate between active and passive given road salts, etc). I'm joining with aluminium and carbon steel and obviously copper-nickle line. Right now, i don't really have any data as for how the lines react with the steel nuts, and it seems stainless is a fairly safe bet, but, runs risks given metallurgy of the aluminium in question and the stainless in question. So, I'm hoping someone can help me sort out some of these unknowns.
i've been doing a lot of reading, and, can't really come to any certain conclusions because it seems there are some base elements to consider, and then, the environmental situation seems to play a huge role. For example, high alloy stainless and cupronickle under theoretical situations react and the copper-nickle alloy should become and anode and corrode heavily. However, http://www.copper.org/applications/marine/cuni/pdf/124_schleich.pdf provided a situation where there was a biofilm over the high alloy stainless and essentially there was no reaction. this is to say, in a normal atmosphere the materials should react, so, this is essentially my point.. I'm not sure where to go with any conclusion.
a major point in this discussion seems to be this "as long as the cathodic surface area(the more noble metal of the galvanic couple) is very small in comparison to the anodic surface area(the less noble metal) no change in corrosion behaviour is observed)" via http://www.euro-inox.org/pdf/map/Contact_with_Other_EN.pdf
However, that reality isn't so well met. The 'nut' in question will be fairly small relative to whatever its being connected to. a nut relative to a small aluminium master cylinder, or even smaller wheel cylinder. However, size ratio to a caliper is probably a 'safe' size difference. There is also the nut itself to the line, which would be about relative to the master cylinder situation, as the line is so small relatively.
A:so, here is my issue consider nuts on the line, brass is essentially out as it will be heavily cathodic relative to aluminium and steel, but, is non reactive to the copper-nickle line. B:stainless is a big mystery, it has little to no reaction with steel, but, potentially is either mildly reactive or non reactive with copper-nickle as well as aluminium. C:steel nuts will be an anode on the line, also potentially taking the line with them, also are corroded easily in oxygen(normal atmosphere) as well as their zinc coating being heavily anodic with copper-nicklehttps://[URL='http://www.fastenal.com/content/feds/pdf/Article%20-%20Corrosion.pdf']www.fastenal.com/content/feds/pdf/Article%20-%20Corrosion.pdf[/URL], however, no reaction with aluminium or steel, yet, everybody seems to use steel nuts..
lastly, there is considerations for the actual connections to the material. the flared end of the copper-nickle hose will be in direct contact with whatever material its being mated to. i guess in europe this stuff is more common and used with success, but, it seems like it should be reacted with any aluminium is contacts??
http://www.npl.co.uk/upload/pdf/bimetallic_20071105114556.pdf (other considerations)
---edit
i apologize, this probably should have been in the materials section
---edit
