Gamma spectrometry: Calibration using X-ray emissions
In summary, the conversation discusses an efficiency calibration measurement for an HPGe detector using Ba-133 and Eu-152 as calibration nuclides, including the use of X-ray emissions for low energy calibration. However, there is a significant difference in the peak at 45.6 keV from Eu-152 compared to the X-ray peaks from Ba-133 and a question about the reason for this difference. The count rates were estimated using Gaussian functions, and the abundance of X-ray emissions for both nuclides were reported from nucleide.org and nucleonica.net. There is also a mention of fitting the peaks automatically using software and comparing the abundance as emitted photons per 100 disintegrations.
Oliver-BfS
I have just done an efficiency calibration measurement for the HPGe detector of a whole-body counter. Ba-133 and Eu-152 were the calibration nuclides. For a calibration at low energies I thought of using the X-ray emissions of both nuclides as well. However, the result looks quite bad - see the attachment.
The peak at 45.6 keV originating from Eu-152 is far too small compared to the X-ray peaks at 30.8 and 35.2 (Ba-133) and at 39.9 (Eu-152). A difference between the emissions of Eu-152 and Ba-133 is possible because of a slightly different distribution of the sources within the phantom. (I used a brick phantom with rod sources.) However, what might be the reason for the difference between the two emissions of Eu-152? The problem occurs also in repeated calibrations so the small number of counts at 45.6 keV is not a random event. The abundance of the X-ray emissions at 45 keV was entered as 14.82%, that at 39.9 keV as 58.5% - values that I found both on nucleide.org and on nucleonica.net. Thank you for your help!
How did you estimate your count rates?
Do they both refer to the same base value?
The count rates were estimated by fitting Gaussian functions to the peaks. This is done automatically by the software (Canberra's Genie 2000). Summing up the numbers of counts per channel and subtracting the continuum background yields a similar number of counts.
Nucleide.org (PDF-File, page 8) reports the abundance as emitted photons per 100 disintegrations.
Related to Gamma spectrometry: Calibration using X-ray emissions
1. What is gamma spectrometry and how does it work?
Gamma spectrometry is a technique used to identify and measure the energy of gamma rays emitted by radioactive substances. It involves the use of a detector, such as a Geiger-Muller tube, which converts the gamma rays into electrical pulses. These pulses are then analyzed to determine the energy and intensity of the gamma rays.
2. Why is calibration necessary for gamma spectrometry using X-ray emissions?
Calibration is necessary to ensure accurate and precise measurements in gamma spectrometry. X-ray emissions, which are known and stable energy sources, are used for calibration to establish a reference point for the detector. This allows for the identification and quantification of unknown radioactive substances.
3. How is X-ray emission used in the calibration process for gamma spectrometry?
X-ray emissions are produced by an X-ray tube, which contains a target material that emits characteristic X-rays when bombarded by high-energy electrons. The energy of these X-rays is known and can be used to calibrate the detector. The intensity of the X-rays can also be adjusted to simulate different levels of radiation for calibration purposes.
4. What factors can affect the calibration of gamma spectrometry using X-ray emissions?
Several factors can affect the calibration of gamma spectrometry, such as the stability and accuracy of the X-ray source, the positioning and stability of the detector, and the presence of any interfering substances. It is important to carefully control these factors to ensure reliable and reproducible results.
5. How often should calibration be performed for gamma spectrometry using X-ray emissions?
Calibration should be performed regularly, ideally before each use, to ensure accurate and precise measurements. It is also recommended to perform calibration after any major changes or adjustments to the instrument or detector. Regular calibration can help to identify any changes or issues with the equipment and ensure the reliability of the results.
  • Atomic and Condensed Matter
  • Nuclear Engineering
10K
