Gardening Project: Flow Rate from pressure requirement
In summary, the individual is trying to determine the appropriate flow rate, in GPH, for a small gardening project that involves maintaining 50 psi (344.7 kPa) inside a 0.170 inch inner diameter vinyl tube with mister nozzles every few inches for a total of 2 feet. The volume of the project is approximately 9 cm^3. They have attempted to use a formula but are unsure if they have applied it correctly. They also mention the possibility of using a sprinkler can as an alternative to a pump. The project is for a classroom aeroponics demonstration and they are trying to find a cheap way to set it up. The individual also discusses the concept of laminar flow and
mishima
576
43
Hi, I have a small gardening project and am trying to decide what kind of pump I need in order to maintain 50 psi (344.7 kPa) inside the line. The line is a 0.170 inch inner diameter vinyl tube with mister nozzles every few inches, for a total of 2 feet. This is a volume of about 9 cm^3.
I would like to know what flow rate, in GPH, I need since this seems to be the most common spec shopping around for pumps.
I tried using:
[tex]\Delta P = \frac{128\mu L Q}{\pi d^4}[/tex]
With viscosity = 10^-3 Pa s, and solving for Q. This gave me a flow rate of .004829 m^3/s which seems to be about 4800 GPH.
I have a feeling that is way too high, and that I have misapplied this equation. I don't know much about fluids, can anyone help?
What is the performance of the individual mister nozzle and how many are there?
It seems to me the tube diameter and volume is irrelevant.
Without seeing your calculation, I wonder whether your huge flow rate, equivalent to an Olympic size pool every day, is calculated on an opening 9cm by 9cm.
In general, it is very much preferable to stick to metric measures for this kind of estimation. The English units are an abomination to work with.
The nozzles should have spec sheets that tell you flow rate and pressure.
The only specification for the nozzles I have is that they are 1.5 GPH. There are 5 nozzles total.
For my calc, I used
d=0.004318 m
L=0.609 m
mu= 0.001 Pa s
P = 344700 Pa
So,
[tex]Q = \frac{\pi Pd^4}{128\mu L}[/tex]
[tex]Q = \frac{3.14*344700*(0.004318)^4}{128*0.001*0.609}[/tex]
[tex]Q = 0.0048 m^3 / s[/tex]
I was also unsure of my value for μ, water with nutrients added at ~20 °C.
http://www.dripirrigation.com/drip_irrigation_categories/111/drip_irrigation_parts/604 is all I know about the nozzles.
Ok, I guess the way to do this is to use the pump manufacturers' "pump curves", which is a plot of pressure vs flow rate. A manufacturer typically plots all of its pumps on the same graph, and each pump has its own curve. You find a point for your required specs (50 psi and 7.5 gph in my case), and then use the pump associated with the curve above your point.
pump up your education
The flow rate you need is 5*1.5 GPH = 7.5 GPH, since you have five nozzles. The formula you were using is for laminar flow conditions.
Your pump curve link shows large pumps (4" and above) which would swamp your project.
This seems like a lot of work. Couldn't you just use a sprinkler can a couple of times a day?
Right, that tutorial is for well pumps, and the pump curves there for demonstration. The pump curves I needed to look at were found on various manufacturers sites.
The flow rate isn't the only thing that matters, I'm using fogger nozzles which are like a fine spray and require a relatively high pressure inside the tubing. For example, a 15 dollar water pump that does 200 gph costing 14 dollars would superficially fulfill my flow rate needs, but in reality if I hooked that up to my nozzle series, the pressure would be insufficient for a mist (it would maybe just drip a little). There is a balance between flow rate and pressure that can only be found with the appropriate pump.
The purpose of the project is a classroom aeroponics demonstration my kids have been interested in (google "NASA aeroponics"). I was hoping to find a cheap way to get one going, since the nozzles and various tubing connections are on the order of a few cents each. The pump is the investment, and it seems after looking into it tonight I can NOT really get away without throwing down ~80 dollars on a water pump.
The alternative would be to use a hose outlet like normal houses have, which easily meet the psi req. The problem is you have to mix the water with nutrients for aeroponics to work, bringing me back to pumps (specifically, submersible, centrifugal). Maybe there is a way to inject nutrients into a hose stream I'm not thinking of.
Eventually I will need a adjustable recycling timer but as well, but that isn't too much. It might be fun to build the timing and control circuit in class.
But SteamKing, as mentioned I've never studied fluid mech in detail. Is it because the velocity of the flow is so great in my setup that a laminar flow assumption is ruled out? Thanks.
Laminar flow is applicable only for low Reynolds numbers (< 2000). The Reynolds number is calculated:
RE = V*D*rho/mu, where rho = 1000 kg/m^3, mu = 0.001 Pa-s, D = 0.004318 m and V= flow velocity in m/s
So, for the tubing,
RE = V*0.004318*1000/0.001 = 4318*V
This means that V must be less than about 0.5 m/s for laminar flow conditions to exist. Any higher flow velocity will become turbulent, and the flow formula from the OP will no longer apply. The Q at 0.5 m/s is equivalent to about 7 GPH, but the formula in the OP gives about 4500 GPH, so something has clearly gone wrong.
Without looking at it in detail, your system has 5 misters placed in only 24" of hose/tubing/whatever. In order for the misters to work properly, 50 psi must be available from the water supply, which means that by the time the fifth mister is reached, that 50 psi must be available, which also suggests that much higher pressure/flow must exist at the first mister. The laminar flow formula in the OP doesn't take this into account. It assumes that the flow velocity and Q are constant over the length of pipe.
Is it necessary to have the pump provide the pressure for your system?
You have a classroom environment, so presumably a school building.
Set up your nutrient reservoir on the second or third floor, lead a pipe down to your project and hydrostatic pressure does the work. All you need to do is to keep the reservoir upstairs filled.
Separately, a two foot long bed getting 7.5 gallons per hour sounds more like a bath than a plant growth demonstration. Are you sure you have all the parameters reconciled? It may be that the use of distinct measuring systems has introduced an error.
So this is really a pump selection issue.
At such low flow and high head, you may have trouble finding a suitable pump. One possibility would be to put two together in series to double the head.
Here's one that would probably do the job. Not cheap though. http://www.northerntool.com/shop/to...cm_pla=Google&cm_ite=https://www.google.com/&
I was actually thinking of doing some rain-barrel irrigation up a small hill, so I would need a similar sized pump. I'll look some more later this afternoon.
There is a simple solution for using the faucet/hose option.
There are many systems that dispense fertilizer directly to the watering hose.
Here is one:
http://www.ezflofertigation.com/
but there are lots of others.
Given that this is a classroom demo, simplicity and low cost rule, plus pumps mean electricals, never a great idea around kids.
Don't blame us for those units any more! We haven't used them in Science and Engineering for 50 years! And if you must refer to them, give them their 'proper' name, which is Imperial Units. At least then we (the British) get a bit of acknowledgment for our past glories (sadly lacking, I fear, in some quarters).
It may be that they have that name in other parts of the World for the same reason that the 'French Disease', in England, was referred to as the 'English Disease', in France, in Napoleon's day. :wink:
etudiant: Nice, I thought something like that probably existed. I will have to inspect the building outside my classroom further, but hopefully there is a tap. There is no water source inside my room either, sadly. I can at least get it going here at home and report my exploits. Thanks for taking a look at this.
FAQ: Gardening Project: Flow Rate from pressure requirement
What is flow rate and why is it important in gardening projects?
Flow rate is the volume of water that flows through a particular point in a given amount of time. In gardening projects, flow rate is important because it determines how much water is delivered to the plants, which is crucial for their growth and health.
How do I calculate flow rate from pressure requirement in a gardening project?
To calculate flow rate from pressure requirement, you will need to use the Bernoulli's equation, which takes into account the pressure and velocity of the water. You will also need to know the diameter of the hose or pipe and the distance the water needs to travel. Once you have these values, you can use an online calculator or do the calculations manually to determine the flow rate.
Can the flow rate be adjusted in a gardening project?
Yes, the flow rate can be adjusted in a gardening project by changing the pressure or the diameter of the hose or pipe. For example, a smaller diameter hose will have a higher flow rate at the same pressure compared to a larger diameter hose.
How does the flow rate affect my watering schedule for plants?
The flow rate affects your watering schedule for plants because it determines how quickly water is delivered to the plants. If the flow rate is too high, the water may not have enough time to be absorbed by the soil and may run off, resulting in overwatering. If the flow rate is too low, it may take longer to water your plants, leading to underwatering.
Are there any tools or devices that can help me measure flow rate in a gardening project?
Yes, there are several tools and devices available to measure flow rate in a gardening project. Some examples include flow meters, pressure gauges, and water timers. These tools can help you accurately measure the flow rate and make necessary adjustments to ensure your plants are getting the right amount of water.
