Gas cylinder at constant pressure being exposed to atmosphere, how?
In summary: there is a simplification in the textbook's explanation of how the gas maintains atmospheric pressure when the piston moves, which is that atmospheric pressure is constant.
bruhtation
TL;DR Summary
a figure in a textbook shows a cylinder filled with gas and one side of the cylinder has a movable piston which is open to the atmosphere, the textbook says "This ensures the gas in the cylinder is always at a constant pressure". how did the book deduce that?
im learning thermodynamics and currently in a lesson about thermal processes. one process has constant pressure and before diving into equations or any proof the book provides a figure of a gas cylinder. the cylinder has a movable piston/lid on one side. the book then says "...and the piston end of the cylinder is open to the atmosphere. This ensures that the gas in the cylinder is always at a constant pressure."
how was the book able to deduce that the cylinder had constant pressure just by the fact that it's piston is exposed to the atmosphere?
i dont know if this is relevant but the book talks about hot-air balloons and pressure in the previous paragraph:
"If you've ever seen a large hot-air balloon being inflated, then you know that the gas in the balloon expands as it is heated. The balloon is surrounded by the atmosphere as it is heated, and the atmosphere is at a constant pressure. Therefore, the heating and expansion of the balloon occur with no change in pressure."
i really didnt understand this part so if anyone can help me out with this too i would really appreciate it.
Science news on Phys.org
In order to pressurize a container different from atmospheric it has to be rigid or otherwise inhibit expansion and contraction. If the balloon were closed and you heated it, the pressure would go up.
If air pressure > cylinder gas pressure, piston moves inward until they have same pressure.
If air pressure < cylinder gas pressure, piston moves outward until they have same pressure.
bruhtation said:
TL;DR Summary: a figure in a textbook shows a cylinder filled with gas and one side of the cylinder has a movable piston which is open to the atmosphere, the textbook says "This ensures the gas in the cylinder is always at a constant pressure". how did the book deduce that?
If the pressure inside the cylinder is greater than atmospheric pressure, the force exerted by the gas on the piston will be greater than the force due to atmospheric pressure on the piston, making the piston move (the gas will expand) until the forces are balanced, meaning that the pressures are equal (since pressure is simply average force per unit area). Note that one usually considers a simplified model, where things like the weight of the piston or its friction against the cylinder are neglected.
Similarly for the balloon. Note however that this is not true of a rubber balloon, where some of the internal pressure is compensated in part by the tensile force of the balloon itself. The pressure inside is then greater than atmospheric pressure.
Likes russ_watters and Lord Jestocost
Not sure if this is what is tripping you up. There is a hidden assumption (really, more of a simplification) in here that - for the purposes of the scenario - atmospheric pressure is constant.
When the piston moves, in response to expansion and contraction of the gas, this allows the gas to always maintain atmospheric pressure.
Likes russ_watters
The internal and external pressures are only the same at the bottom opening of a hot air balloon. Hydrostatic pressure falls as you rise, at a rate proportional to density. The air inside the balloon is less dense, so the pressure falls slower inside the envelope than in the atmosphere outside. In the upper parts of the balloon, there is a greater internal hydrostatic pressure remaining than there is outside. That differential pressure lifts the envelope, and so the balloon.
The pressure of the gas inside the cylinder is equal to atmospheric pressure PLUS the pressure exerted by the piston in response to gravity.
Please write down the Newton's 2nd law force balance equation for the piston as a free body, letting ##F_g## represent the force that the gas exerts on the piston during the process.
That kind of depends on the piston's weight, location and orientation, don't it? 🤔 And one of that is specified.Regardless, we are explicitly told to ignore it:
"Note that one usually considers a simplified model, where things like the weight of the piston or its friction against the cylinder are neglected."
FAQ: Gas cylinder at constant pressure being exposed to atmosphere, how?
What happens to the gas inside the cylinder when it is exposed to the atmosphere?
When a gas cylinder at constant pressure is exposed to the atmosphere, the gas inside the cylinder will tend to equalize its pressure with the atmospheric pressure. If the atmospheric pressure is lower than the pressure inside the cylinder, the gas will escape to the surroundings until equilibrium is reached.
How does temperature affect the gas in the cylinder when exposed to the atmosphere?
The temperature of the gas can affect its pressure and volume. According to the ideal gas law (PV=nRT), if the temperature of the gas increases while the cylinder is exposed to the atmosphere, the pressure inside the cylinder could increase, causing more gas to escape. Conversely, if the temperature decreases, the pressure inside the cylinder could decrease, potentially reducing the rate at which gas escapes.
Can the material of the cylinder affect the gas release when exposed to the atmosphere?
Yes, the material of the cylinder can affect how the gas is released. If the cylinder material is a good conductor of heat, it may quickly reach thermal equilibrium with the surrounding atmosphere, affecting the pressure and volume of the gas inside. If the material is more insulative, the gas release might be slower as the internal temperature changes more gradually.
Is it safe to expose a gas cylinder to the atmosphere?
Exposing a gas cylinder to the atmosphere can be safe or dangerous depending on several factors, including the type of gas, the pressure inside the cylinder, and environmental conditions. For instance, flammable or toxic gases pose significant risks and should be handled with extreme caution. Safety protocols and proper equipment should always be used to mitigate risks.
What precautions should be taken when exposing a gas cylinder to the atmosphere?
Precautions include ensuring the cylinder is in good condition without leaks, using proper protective equipment, and being aware of the properties of the gas (e.g., flammability, toxicity). It is also important to conduct the process in a well-ventilated area or use appropriate ventilation systems to prevent the accumulation of hazardous gases. Monitoring devices for gas concentration may also be necessary to ensure safety.
