Gas flow units MSCMD, KM^3 and SM^3x10
In summary, the conversation discusses the confusion between the units kM3/d and cubic meters per day, and whether they are equivalent to a kilometer cubed per day. The participants suggest comparing the size of pipes and considering factors such as gas velocity and combustion requirements to gain a better understanding of the measurements.
rolls
52
Is kM3/d 1000 m^3 a day or a kilometre^3 a day?
I know it should be little m but this is what is written on our gas measuring instrument
Are the units kM3/day 1000 cubic metres per day, or a kilometre cubed per day eg 1000x1000x1000 m^3 = 1e9
Thanks
Take a look back, and compare the size of pipes going into the gas meter and where the gas is going to get a reality check for your two versions...
If this is a low pressure gas main going to a burner, convert the volume per unit time to the linear velocity of gas through one meter of pipe; for cubic kilometers of gas per day, the 10E09 cubic meters can be determined to still be an absurdly large amount of gas per second...
(over 150,000 cubic meters per second!). Even with a pipe with a cross section of 1 square meter, the linear velocity bogles the mind for low pressure gas passing across one meter. It would scream! not to mention what it means in terms of smaller pipe diameters likely to be found feeding the gas meter.
Also think if this is CH4 feeding a burner, how many moles of gas and therefore how many moles of air need to be available to combust the gas... The heat value, mass balances, and CO2 evolved per unit time could also be points for reality checks...
Yeah that was what I was thinking, a km^2 is just a ridiculous amount of gas.
Thanks.
Related to Gas flow units MSCMD, KM^3 and SM^3x10
What are MSCMD, KM^3, and SM^3x10?
MSCMD stands for Million Standard Cubic Meters per Day, KM^3 stands for Kilometers Cubed, and SM^3x10 stands for Standard Cubic Meters multiplied by 10.
What do these gas flow units measure?
These gas flow units measure the amount of gas that is flowing per unit of time or volume.
What is the difference between MSCMD and SM^3x10?
The main difference between MSCMD and SM^3x10 is the unit of measurement. MSCMD measures the volume of gas in millions of standard cubic meters per day, while SM^3x10 measures the volume in standard cubic meters multiplied by 10.
How are these units converted into each other?
To convert MSCMD into SM^3x10, you can multiply the value by 10. To convert KM^3 into SM^3x10, you can multiply the value by 1 billion. There is no direct conversion between MSCMD and KM^3.
What is the significance of using standard units for measuring gas flow?
Standard units, such as standard cubic meters, provide a common basis for measuring gas flow. This allows for accurate and consistent measurements across different locations and conditions, making it easier to compare and analyze data.
  • Materials and Chemical Engineering
