Gas inside an expandable cylinder raises lid on spring
In summary: And you are welcome - glad to help!In summary, the conversation discusses how to calculate the height of an expandable cylinder with a spring attached to its top when the temperature is raised. Using the ideal gas law, the equation (PV/T)initial = (PV/T)final is derived and units are carefully considered. After solving the quadratic equation, the correct answer of 0.169m is obtained.
astrocytosis
51
An expandable cylinder has its top connected to a spring of constant 2000 N/m. The cylinder is filled with 5L of gas with the spring relaxed at a pressure of 1 atmosphere and a temperature of 20C. If the lid has a cross-sectional area of 0.01m2 and negligible mass, how high will the lid rise when the temperature is raised to to 250C?
PV = nRT
PV/T initial = PV/T final
P = Force/Area. When the gas expands it pushes on the spring which pushes back with F = k * displacement. Displacement here is h so P=kh/A. We already know the initial pressure is 1 atmosphere, so the final P is kh/A + 1.
The initial volume is 5L, so the final volume must be 5 + Ah.
The initial temperature and final temperature are given as 20 and 250C.
Plugging that in gives:
(1*5)/20 = (1 + kh/A)(5 + Ah)/250
62.5 = (1 + kh/A)(5 + Ah)
which yields a quadratic:
62.5 = 5 + Ah + 5kh/A + kh2
Ah = .01h and 5kh/A = 106h so Ah can be neglected when adding these terms ≈ 106h.
0 = -57.5 + 106h + 2000h2
When I solve this quadratic equation I get h = 5.75E-5. But this isn't the right answer. I'm stuck on figuring out where I went wrong so help is very appreciated. Thank you!
I think you are setting it up correctly. But you need to watch your units. Plug in units along with the numbers to make sure the terms in your equations are consistent in units.
If I write out units I get
(1 atm)(5 L)/(20 C) = (1 atm + kh/A m-1)(5 L + Ah m2)/(250 C)
.25 atm*L/C = (5 atm*L + 5kh/A L*m-1 + kh2m2)/(250 C)
(.25 atm*L/C)*(250 C) = 62.5 atm*L = 5 atm*L + 106h/A L*m-1 + 2000h2m2)
57.5 atm*L = 106h/A L*m-1 + 2000h2m2)
L can be converted into m3:
(57.5 atm*L)(.001m3/L) = 106h/A L*m-1*(.001m3/L) + 2000h2m2)
.0575 atm*m3= 4hm2 + 8h2m2
But I am not sure what to do now that I see the units on either side are different.
(PV/T)initial = (PV/T)final is a result of the ideal gas law PV = nRT. What type of temperature scale is required for T here?
The spring constant is given in N/m which are units belonging to the SI system of units. Are the liter and the atmosphere SI units for volume and pressure?
Ok, so now I have:
(1.01E5 N*m-2)(.005 m3)/(293 K) = (1.01E5 N*m-2 + kh/A N*m-2)(.005 m3 + Ah m3)/(523 K)
(523/293)(.005)(1.01E5 N*m) = (1.01E5 N*m-2 + kh/A N*m-2)(.005 m3 + Ah m3)
But that simplifies to:
(523/293)(.005)(1.01E5 N*m) = (.005)(1.01E5) N*m + (.01)(1.01E5)h N*m + (.005)(2000)/(.01)h N*m + (.01)(2000)/(.01)h2 N*m
which is in N*m and it should be in meters.
That looks good. Note that you have shown that each term has total units of N*m. So, your equation is consistent in terms of units. That doesn't mean that h has units of N*m. You have already taken account of the fact that h has units of meters in order to obtain units of N*m for the terms that contain h. So, in your way of writing the equation, h is now just a number without units since you have already included the unit for h when writing N*m for the entire term.
This is not the usual way to write it. The usual way to write, say, the term (.01)(1.01E5)h with units would be
(.01 m2)(1.01 x 105 N/m2)h = [(.01)(1.01 x 105) N]h = (1.01 x 103 N)h.
The units for h are not written explicitly here, but it is assumed that h carries the units of meters.
Overall, the expression (1.01 x 103 N)h still has units of N*m, where the m comes from the units of h.
Likes astrocytosis
When I plugged in everything and solved the quadratic I got .169m, which is the correct answer. I have always had trouble with units so this was very helpful, thank you!
OK, good work!
FAQ: Gas inside an expandable cylinder raises lid on spring
What is the purpose of the gas inside an expandable cylinder?
The gas inside an expandable cylinder serves as a source of pressure that allows the cylinder to expand and raise the lid on the spring.
How does the gas inside the cylinder raise the lid on the spring?
When the gas inside the cylinder is heated, it expands and increases the pressure inside the cylinder. This pressure pushes against the lid, causing it to raise on the spring.
What type of gas is typically used in an expandable cylinder?
The type of gas used in an expandable cylinder can vary, but common choices include air, nitrogen, and carbon dioxide.
Can the amount of gas inside the cylinder affect the height that the lid raises?
Yes, the amount of gas inside the cylinder can affect the height that the lid raises. The more gas there is, the higher the pressure and the greater the force pushing against the lid.
Is it possible for the lid to get stuck in the raised position due to the gas inside the cylinder?
No, the lid should not get stuck in the raised position due to the gas inside the cylinder. The gas will continue to expand until it reaches equilibrium with the surrounding atmosphere, at which point the lid will remain in place.
10K
10K
