Gas law and finding the pressure
In summary, the ideal gas law is a fundamental equation that relates the pressure, volume, temperature, and number of moles of a gas. It is represented by the equation PV = nRT. To find pressure using this law, you would rearrange the equation to solve for P. There are two types of pressure: absolute and gauge. Absolute pressure includes atmospheric pressure, while gauge pressure is relative to atmospheric pressure. According to the ideal gas law, as temperature increases, so does gas pressure. Gas pressure can be measured in units such as Pascals, atmospheres, millimeters of mercury, or pounds per square inch.
Scarlet_pat
44
a container of gas has a volume of 0.1 m^3, at a pressure of 200000 Nm^-2 and the temperature 27 C, find the new pressure if the gas is heated at constant volume to 87 C.
P1/P2 = T1/T2
pV / T = R ( constant)
i tried to plug those values into the equations however the answer is not corresponded to the back of the book.
thank you very much
nvm i have found the solution .. thank you very much
FAQ: Gas law and finding the pressure
What is the ideal gas law?
The ideal gas law is a fundamental equation in thermodynamics which describes the relationship between the pressure (P), volume (V), temperature (T), and number of moles (n) of a gas. It is represented by the equation PV = nRT, where R is the universal gas constant.
How do you find pressure using the ideal gas law?
To find pressure using the ideal gas law, you would rearrange the equation to solve for P. This would give you the formula P = nRT/V. Simply plug in the values for n, R, T, and V to calculate the pressure.
What is the difference between absolute and gauge pressure?
Absolute pressure is the total pressure exerted by a gas, including atmospheric pressure. It is measured relative to a perfect vacuum. Gauge pressure, on the other hand, is measured relative to atmospheric pressure and does not take into account atmospheric pressure.
How does temperature affect gas pressure?
According to the ideal gas law, as temperature increases, so does the pressure of a gas. This is because as temperature increases, the average kinetic energy of gas molecules also increases, causing them to collide with the container walls more frequently and with greater force, resulting in a higher pressure.
What units are used to measure gas pressure?
The SI unit for pressure is the Pascal (Pa). However, gas pressure is often measured in other units such as atmospheres (atm), millimeters of mercury (mmHg), or pounds per square inch (psi). These units can be converted to each other using conversion factors.
