Gas Laws -- An astronaut breathing presurized air
In summary, an astronaut on a spacewalk has a pressurized oxygen tank with a volume of 15 liters and a pressure of 5 atmospheres. When pumped to the astronaut's mouth at atmospheric pressure, the maximum volume of oxygen available to the astronaut is calculated using the gas laws. However, in reality, the amount of oxygen available is less than the calculated value due to factors such as the decreasing number of oxygen molecules and the constant pressure at the mouthpiece. The assumptions made about the gas, including the constancy of mass and temperature, may not fully reflect the actual conditions.
  • #36
BvU said:
And no, the volume of the tank remains 15 liter. So guess what decreases ?
the tank's volume remains the same but the question asks why he would have a lower volume of oxygen than calculated.
  • #37
haruspex said:
Not quite that directly - that's a popular misunderstanding.
First, it is not always true that it's colder at higher altitude. Temperature 'inversions' can occur. The primary reason it's colder is because the atmosphere is heated from the bottom by the insolation of the Earth's surface, and loses heat into space at the top. So with no convection it would be much colder at higher altitudes. But heated air expands and becomes less dense, so rises. This convection tends to spread the heat evenly up through the atmosphere (at least, as far as the tropopause). As against this, as a given parcel of warm air rises it expands further because of the lower pressure, and in expanding it 'does work', pushing aside other air. The energy for that work comes from the heat in it, so it cools. (This is an example of adiabatic expansion.) Thus convection can only occur when the temperature gradient is steep enough.
For the present problem, the key part in all that is the bit about air cooling as it is allowed to expand.
sorry if this is a stupid question, but why would the air in the tank be heated? Is it the bit about the atmosphere's heat that you mentioned?
  • #38
What you'vev been taught is just fine. I just want to point out that maybe not all of these 75 liters are available for the poor astronaut, even in an ideal case.
And yes, the temperature decreases: the gas has to do some work to expand, which cools it down. If there's nothing to maintan the temperature, the 1 Bar is reached before the 15 liter has expanded to 75 liters
  • #39
ah ok, i considered that earlier but the other guy disagreed?
so because the pressure has decreased, the oxygen becomes less dense and expands, this makes it lose heat energy to work, therefore it cools down and is already at the lower pressure without being able to expand fully to the maximum volume?
  • #40
BvU said:
I was afraid of that. Based on 5 x 15 = 1 x 75. However, once the pressure in the tank is down to 1 bar (105 Pa - one atmosphere is 1.01325 Bar !), don't you think the flow of oxygen stops ?
We have that weird notion of a pump in the problem statement, so we don't know.
I think this is the expected answer.
The problem statement is so unrealistic that it is hard to guess which part should be assumed to be realistic.
  • #41
There are two different volumes here. There's the volume of the tank, which does not change, and there's the volume of gas as presented to the astronaut. The gas is originally at tank volume and the given pressure, but all ends up (eventually) at 1 atm. You calculated the total volume as breathed from the original volume by considering the change in pressure. But that simple calculation assumed constant temperature. The discussion now concerns why the temperature may change.
It is a bit complicated because while the tank is at greater than 1 atm the gas does work in expanding, so cools the tank. Once the pressure is below 1 atm the pump kicks in. I'm not well enough versed in thermodynamics to say what happens to the temperature then.
  • #42
BvU is overlooking the mention of a pump.
  • #43
Haru: Sure, they mention a pump. For the last 15 liter only ? They mention 1 Bar, too. In a zero pressure environment. They don't mention CO2 (http://spaceflight.nasa.gov/shuttle/reference/faq/eva.html does; apparently they work at 1/3 Bar). I figured the 15 liter would be a nice and simple booby trap in the exercise, which (post #40) is grossly unrealistic. Didactically rather unsatisfactory. My impression is that pV = nRT is all the students are supposed to carry when doing this exercise.
  • #44
ah ok, thank you
  • #45
ok so i'll write about how pressure ch
ok, thanks a lot everyone:)
