hadroneater
- 59
1) If air contains 1% AR by volume, what is the mass of Argon in a 2L balloon of air at 25 degress celsius?
2) If for a real gas, P = RT(V - b) - a/V^2
where a and b and R are constants, P = pressure, T = temperature and V = volume.
What does a large a value represent in a real gas?
3)A small pond has a layer of ice 1cm thick foating on its surface.
(a) If the air temperature is -10 degrees C, find the rate in cm per hour at which ice is added to the layer. The thermal conductivity of ice is 0.592 W/mK.
(b) How long does it take for a 20cm layer to build up?
1) pV=nRT Ptotal = p1 + p2...pn
3) H = k*A*dT/L
1) I'm not sure if I'm supposed to use the simple addition equation where pressure of argon is just 1% of the total pressure.
2) Obviously the gas would have lesser volume as a increases. But why do non-ideal gases exhibit this pressure drop?
3) heat associated with freezing 1cm^3 water = mL = 0.001g * 334*10^3 = 334J
That's really as far as I got...
