Gas-liquid absorption design problem
In summary, the conversation discusses the process of designing an absorption tower to remove pure CO2 from a natural gas stream. The design involves using a propylene carbonate solvent and calculating the number of overall gas transfer units (OGTUs) required to reach the desired CO2 concentration. The steps for calculating OGTUs are outlined, including determining the equilibrium CO2 loading of the solvent, calculating the gas phase mass transfer coefficient, and using equations to determine the overall mass transfer coefficient and number of theoretical stages needed.
Yr11Kid
Hey everyone
i'm in the process of designing an absorption tower (packed) to remove pure CO2 from a natural gas stream flowing at 25 MMscfd.
The natural gas contains 8% CO2 initially, and must contain 3% CO2 on exiting the tower.
The feed gas inlet conditions are 298K and 6900kPa
i've decided to use a propylene carbonate solvent
The CO2 absorption into the solvent at the process conditions follows henrys law
Basically i want to know how i would go about calculating the number of overall gas transfer units required to reach the 3% CO2 specification.
Hi there,
Calculating the number of overall gas transfer units (OGTUs) required for your absorption tower is a crucial step in the design process. OGTUs represent the number of times the gas stream needs to come into contact with the solvent in order to reach the desired CO2 concentration. Here is a step-by-step guide on how to calculate OGTUs for your specific system:
1. Determine the equilibrium CO2 loading of your solvent at the process conditions. This can be done using Henry's Law, as you mentioned, or by using a CO2 solubility table for propylene carbonate.
2. Calculate the difference in CO2 loading between the inlet and outlet gas streams. In your case, it would be 8% - 3% = 5%.
3. Convert the CO2 loading difference to a concentration difference. This can be done by multiplying the loading difference by the molecular weight of CO2 (44 g/mol) and dividing by the molecular weight of natural gas (approximately 16 g/mol). In this case, it would be (5% * 44 g/mol) / 16 g/mol = 13.75%.
4. Determine the height of your packed tower and the packing material used. This information is needed to calculate the overall mass transfer coefficient (Kya) for your system.
5. Calculate the gas phase mass transfer coefficient (Kga) using the following equation:
Kga = 0.00002 * (gas flow rate in m3/hr) / (packing height in meters)
6. Calculate the overall mass transfer coefficient (Kya) using the following equation:
Kya = (Kga * (solvent density in kg/m3)^0.5) / (solvent viscosity in kg/m*s)
7. Calculate the overall gas transfer units (OGTUs) using the following equation:
OGTUs = (packing height in meters) * (Kya / (overall mass transfer coefficient at infinite height))
8. Finally, calculate the number of theoretical stages required for your absorption tower using the following equation:
Number of theoretical stages = OGTUs / (height of a theoretical stage in meters)
I hope this helps you in your design process. Best of luck with your absorption tower!
Related to Gas-liquid absorption design problem
1. What is gas-liquid absorption design problem?
The gas-liquid absorption design problem is a common issue faced by scientists and engineers in the field of chemical engineering. It refers to the challenge of designing a system that can effectively transfer a gas (such as carbon dioxide) from a gas phase to a liquid phase (such as water) through absorption.
2. What factors should be considered in gas-liquid absorption design?
When designing a gas-liquid absorption system, several factors must be taken into consideration. These include the properties of the gas and liquid, the contact area between the two phases, the mass transfer rate, and the overall efficiency of the system.
3. What are some common methods used in gas-liquid absorption design?
There are several common methods used in gas-liquid absorption design, including packed columns, tray towers, and membrane contactors. Each method has its advantages and disadvantages, and the choice of method depends on the specific application and desired outcomes.
4. How can the efficiency of gas-liquid absorption be improved?
To improve the efficiency of gas-liquid absorption, several strategies can be employed. These include increasing the contact area between the gas and liquid phases, optimizing the mass transfer rate through the use of appropriate equipment and materials, and controlling the operating conditions to minimize losses.
5. What are some challenges in gas-liquid absorption design?
Some common challenges in gas-liquid absorption design include maintaining a high efficiency while minimizing the size and cost of the system, dealing with variable feed gas compositions, and managing the potential for fouling or corrosion of equipment. Additionally, the selection of appropriate materials and the consideration of safety and environmental factors are important in the design process.
  • Materials and Chemical Engineering
37K
  • General Discussion
14K
