voltech444
- 32
- 1
Hey I've been thinking of this idea for a while,
If I had a small boat with a home made gas turbine engine on it to power it solely with thrust. If I put an afterburner on it and nozzle; and had a small intake for water that filtered out all of the crud. Would it be possible to generate more thrust by injecting the water into the afterburner? Not like other types of water injection that inject water before the compressor or in the combustion chamber, but after the power turbine wheel in an afterburner like device. Not adding any extra fuel in the afterburner just spraying a mist of water.
My thinking is that the super hot gases coming out of the power turbine would super heat this water mist into steam. This would create a lot of extra pressure and mass and add another gas coming out to produce more thrust. The water droplets would flash vaporize into steam and cause a lot more pressure and mass.
I know a similar technique is used in other aircraft for short periods of time to get extra power but they are injecting the water before the compressor and in the combustion chamber. In the setup I am talking about it wouldn't change the operation of the turbine it would just take advantage of the hot gases coming out as thrust.
I understand why this technique is not used on commercial aircraft because of the heavy weight of the water required, but on a boat where there's unlimited water something like this could be viable
What do you think?
Thank you,
Jordan
What do you think?
Thank you,
Jordan
