Gas, vapor, clouds any difference?
In summary, most of the water in the atmosphere is in the gas state as water vapor, but some can condense into tiny droplets of liquid water. The proportion of water in the atmosphere as individual molecules and liquid droplets varies and can depend on temperature and pressure. Other gases can also form droplets and rain in certain conditions. Water vapor is not visible, but clouds are made up of tiny droplets of liquid water, not water vapor.
Doug1943
37
Gas, vapor, clouds ... any difference?
"Most of the water in the atmosphere is in the gas state called water vapor." (http://www.srh.noaa.gov/srh/jetstream/atmos/ll_rainman.htm)
This quote was taken from a site dealing with weather.
Does this mean that the average temperature of the water in the atmosphere is 100 degrees Celsius or more? Or is this statement confusing the gas state, with a particular way that liquids can exist, namely as clusters of molecules which are too small to be seen, and which, although their density is greater than that of air, are small enough to stay afloat in air for the same reason that particles of dust stay afloat, which, I assume, is due to being light enough to be lifted by random air currents.
Comments?
Water vapor can exist quite happily in the air at temperatures lower than 100 Celsius. The significance of the boiling point is not that water vapor cannot exist below it, but rather that liquid water cannot exist above it.
So most of the water in the atmosphere is indeed water vapor, water in its gaseous form. Some, however, does condense out into tiny droplets of liquid water (or crystals of ice), which if tiny enough will stay afloat as clouds, contrails, and fog.
Water vapor can (and does) exist at temperatures below 100 degrees.
Even below 0 Celsius. So you don't have to imagine some exotic form of liquid water in the atmosphere.
However there is water in the form of liquid droplets too. For example in some clouds.
'Humidity' is a measure of how much water vapor the atmosphere contains.
If you put a saucer of water out, the water will eventually evaporate into the atmosphere, even though the temperature is nowhere near 100 C.
Do not confuse the process of 'evaporation' with the process of 'boiling'.
Clouds are not vapor, but gas is.
So, most of the water in the atmosphere is in the form of individual water molecules, not clustered together with other water molecules in the form of tiny micro-droplets? And these -- presumably what we see as clouds -- are not called water vapor? (In other words, 'water vapor' is just a synonym for 'water in the gaseous state'?)
What proportion of water in the atmosphere is individual water molecules (i.e. gas/water vapor), and what proportion is 'floating liquid', i.e. condensed micro-droplets?
And ... if individual water molecules can condense into tiny liquid floating micro-droplets, can any other common gas do this (at near STP)?
Could we imagine very different temperatures and pressures where we could get micro-droplets (and perhaps rven 'rain') of, say, carbon dioxide molecules?
One other question: when students are told that 'liquids take the shape of their container' but 'gases expand to fill their container' ... this presumably doesn't mean water in the form of micro-droplets? It really means 'liquids where the molecules have clustered together in such great numbers that they are not buoyed up by any surrounding fluid".
Doug1943 said:
S
Could we imagine very different temperatures and pressures where we could get micro-droplets (and perhaps even 'rain') of, say, carbon dioxide molecules?
yes. cloud and rain formation require fairly large volumes (it's much easier to form droplets on a convenient solid surface, as in distillation) so there may not be any realistic examples on earth... but it's easy to imagine.
There are many, many, different molecular species which constitute what we call air: methane, CO2, oxygen, nitrogen, CO, water, NO, NO2, HNO3, HCl, N2O5, ClO, ClNO3, and others. All of them can be made to condense out if we raise the pressure and lower the temperature enough. Also, all of them will dissolve in water droplets to a small extent.
Clouds on other planets (especially the gas giants) have nothing to do with water. While water has some very particular properties, on some general level it behaves the same way other gases do. In every mixture of gases in the correct range of pressures and temperatures there will be clouds and rains.
Having read through the above, I feel I should point out that the water vapour in the atmosphere is no different from all the other gas molecules up there. The partial pressures of all the gases go to make up the total pressure in the atmosphere. Air is not 'like a sponge'. Water does totally its own thing. The partial pressure of water vapour, in the presence of liquid water will be the vapour pressure corresponding to its temperature and that's what will govern the amount of water vapour. (I am, of course, talking in terms of the equilibrium state of a fixed mass of air over a water surface; the weather is constantly giving non-ideal conditions).
Water vapor is clear - what you see as clouds is actually a collection of small water droplets. Water vapor is everywhere in the atmosphere though, not just in the clouds.
Related to Gas, vapor, clouds any difference?
What is the difference between gas, vapor, and clouds?
Gas is a state of matter where particles are widely spread and move freely. Vapor is a gas that is typically in its liquid or solid state at room temperature, but has been heated to become a gas. Clouds are visible masses of water droplets or ice crystals suspended in the atmosphere.
Can gas turn into vapor?
Yes, gas can turn into vapor when it is heated to a temperature higher than its boiling point. This process is called vaporization.
Are gas and vapor the same thing?
No, gas and vapor are not the same thing. Gas is a state of matter, while vapor is a specific type of gas that is typically in its liquid or solid state at room temperature.
How are clouds formed?
Clouds are formed when water vapor in the air condenses into tiny droplets or ice crystals. This happens when warm air rises and cools, causing the water vapor to reach its dew point and turn into visible clouds.
Can clouds be made of gas or vapor?
No, clouds are not made of gas or vapor. While clouds do contain water vapor, they also contain tiny droplets or ice crystals, making them a different state of matter than gas or vapor.
  • Mechanical Engineering
  • Other Physics Topics
  • Classical Physics
  • Materials and Chemical Engineering
