Gauge Invariance for field of *Uncharged* particles?
In summary, a classical field of uncharged particles cannot be made gauge invariant because it is not affected by gauge transformations. However, the Lagrangian must still be invariant under gauge transformations, resulting in the covariant derivative being equivalent to the partial derivative.
LarryS
33
A complex classical field Φ of particles is, by itself, invariant under global phase changes but not under local phase changes. It is made gauge invariant by coupling it with the EM potential, A, by substituting the covariant derivative for the normal partial derivative in the Lagrangian. But if the particles represented by Φ have zero electrical charge, the covariant derivative is the same as the normal derivative.
Does that mean that a classical field of uncharged particles cannot be made gauge invariant?
Thanks in advance.
Likes DuckAmuck
If it is uncharged it is not affected by the gauge transformation and therefore the covariant derivative is equivalent to the partial derivative. The kinetic term is still gauge invariant, because the field does not transform under gauge transformations.
Likes vanhees71
I think I understand. Are you saying that gauge invariance is irrelevant for classical fields representing a system of uncharged particles?
It is not irrelevant. It is just that an uncharged field does not transform under gauge transformations. If you have a local symmetry, the Lagrangian still needs to be invariant under gauge transformations, but this implies the covariant derivative being equal to the parial derivative. In general, the covariant derivative is given by ##D_\mu = \partial_\mu - i g A^a_\mu \tau^a## where ##\tau^a## is the representation of the gauge group generator in the relevant representation. An uncharged field corresponds to transforming under the trivial representation where ##\tau^a = 0##.
FAQ: Gauge Invariance for field of *Uncharged* particles?
1. What is gauge invariance for uncharged particles?
Gauge invariance is a fundamental principle in physics that states that the physical laws governing a system should not depend on the choice of gauge used to describe the system. In the context of uncharged particles, this means that the equations describing their behavior should remain the same regardless of the specific gauge chosen.
2. Why is gauge invariance important for uncharged particles?
Gauge invariance is important because it allows for a consistent and unified description of physical laws. It also helps to eliminate unphysical solutions and redundancies in the equations, leading to a more elegant and precise understanding of the behavior of uncharged particles.
3. How is gauge invariance maintained for uncharged particles?
Gauge invariance is maintained by introducing a gauge potential, which is a mathematical quantity that transforms in a specific way under a change of gauge. By choosing the gauge potential appropriately, the equations governing the behavior of uncharged particles can be made invariant under gauge transformations.
4. What are some examples of gauge invariance for uncharged particles?
One example of gauge invariance for uncharged particles is in electromagnetism, where the gauge potential is the electromagnetic vector potential. Another example is in quantum field theory, where the gauge principle is used to describe the interactions between fundamental particles.
5. How does gauge invariance for uncharged particles relate to other fundamental principles in physics?
Gauge invariance is closely related to other fundamental principles in physics, such as symmetry and conservation laws. In fact, gauge transformations can be thought of as a type of symmetry transformation, and the conservation of certain quantities (such as electric charge) is a direct consequence of gauge invariance.
