Gauge invariance in GR perturbation theory
In summary, the conversation discusses the concept of gauge invariance in perturbation theory and how it relates to coordinate transformations. The Lie derivative and covariant derivative are used to understand the change in the metric components, and when the change is zero, the perturbation is said to be gauge invariant. This means that the resulting metric is independent of the choice of coordinates.
victorvmotti
155
I have been following [this video lecture][1] on how to find gauge invariance when studying the perturbation of the metric.
Something is unclear when we try to find fake vs. real perturbation of the metric.
We use an arbitrary small vector field to have the effect of a chart transition map or coordinate transformation.
When the change in the metric is given by Lie derivative of the metric along the vector field it is said that the change in the metric components is due to the coordinate change and therefore fake.
But it is unclear to me why we apply "the change" of the $$\delta g_{ab}$$ along the arbitrary small vector field $$\xi$$ and conclude that
$$\Delta_{\xi}\delta g_{ab}=\mathcal{L}_{\xi} g_{ab}$$
**Q1: Shouldn't it be that
$$\delta g_{ab}=\Delta_{\xi} g_{ab}=\mathcal{L}_{\xi} g_{ab}$$**
**Q2: Also, we assume that when
$$\Delta_{\xi}\delta g_{ab}=0$$ then the $$\delta g_{ab}$$ is not fake and therefore $$g_{ab}+\delta g_{ab}$$ an objective new metric, but how?**
[1]:
Thank you for bringing up this interesting and important question about gauge invariance in perturbation theory.
To answer your first question, it is important to understand the difference between the Lie derivative and the covariant derivative. The Lie derivative represents the change in a tensor field along a vector field, while the covariant derivative accounts for the change in a tensor field due to a change in the underlying coordinate system. In the case of gauge transformations, we are interested in the change in the metric components due to a change in coordinates, which is why we use the covariant derivative. Therefore, it is correct to write:
To answer your second question, when $\Delta_{\xi}\delta g_{ab}=0$, it means that the change in the metric components due to the coordinate transformation is zero. This implies that the perturbation is not affected by the choice of coordinates, which means it is a true physical perturbation and not a fake one. In other words, the perturbation is gauge invariant. Therefore, $g_{ab}+\delta g_{ab}$ is an objective new metric that is independent of the choice of coordinates.
I hope this helps clarify your doubts. If you have any further questions, please do not hesitate to ask. Keep up the good work in studying gauge invariance in perturbation theory!
Related to Gauge invariance in GR perturbation theory
1. What is gauge invariance in GR perturbation theory?
Gauge invariance refers to the property of a physical theory where the mathematical description of the theory remains unchanged under certain transformations. In GR perturbation theory, gauge invariance ensures that the equations describing the behavior of small perturbations in the gravitational field are independent of the choice of coordinates used to describe the spacetime.
2. Why is gauge invariance important in GR perturbation theory?
Gauge invariance is important in GR perturbation theory because it allows for a more general and flexible description of the gravitational field. It ensures that the equations describing the behavior of perturbations are not affected by arbitrary choices of coordinates, making the theory more physically meaningful and easier to interpret.
3. How is gauge invariance maintained in GR perturbation theory?
Gauge invariance is maintained in GR perturbation theory through the use of gauge transformations. These transformations involve making changes to the coordinates used to describe the spacetime, while keeping the physical quantities and equations describing the perturbations unchanged.
4. What are the consequences of violating gauge invariance in GR perturbation theory?
If gauge invariance is violated in GR perturbation theory, the equations describing the behavior of perturbations will depend on the choice of coordinates used. This can lead to inconsistencies and difficulties in interpreting the physical meaning of the theory.
5. How does gauge invariance relate to the principle of general covariance in GR?
Gauge invariance is closely related to the principle of general covariance in GR. Both principles ensure that the equations describing the behavior of the gravitational field are independent of the choice of coordinates used. However, while general covariance applies to the entire theory of GR, gauge invariance specifically pertains to the behavior of small perturbations in the gravitational field.
9K
