Gauge theory with non-dynamical gauge field
In summary, the speaker is seeking to write a Lagrangian that is invariant under local ISO(3) transformations. They have found that out of the 6 gauge fields needed, 3 of them are non-dynamical and only appear as sources in the covariant derivative. The speaker is questioning if this is acceptable or if there are any issues with this approach. Another participant suggests that in the classical theory, gauge constraints can be used to pick one representation out of many, but in quantum field theory, Faddeev Popov ghost fields must also be introduced to ensure causality and unitarity. They also mention that this construction is similar to gauging ISO(1,3) in order to obtain General Relativity and
Einj
470
59
Hello everyone, I'm trying to write down a Lagrangian invariant under local ISO(3) (rotations+shifts) transformations. I'm working at classical level and there will be no quantization of any kind so the theory shouldn't have any ghost pathology.
However, I found that, out of the 6 gauge fields needed, 3 of them are non-dynamical, i.e. they don't admit a kinetic term in the Lagrangian but they only appear in the covariant derivative of the fields, like a source. However, they also transform non-trivially under local ISO(3) (of course).
Is there anything pathologically wrong in it or can I just accept the fact that they are non-dynamical?
Thanks a lot!
In the classical theory, the physical degrees of freedom are represented by an entire class of gauge potentials. For a massive (massless) vector field, represented by a four-vector field, only 3 (2) field degrees of freedom are physical. You need a gauge constraint to pick one representation out of the infinitely many connected by a gauge transformation. In the classical theory that's all you need.
In quantum field theory you have to make sure that you get well-defined propagators for the gauge fields which again make it necessary to fix the gauge. At the same time you must make sure that the non-physical field-degrees of freedom do not become interacting and thus violate causality and unitarity of the S matrix. For that you have to introduce Faddeev Popov ghost fields, which is most easily seen in the path-integral formalism.
Isn't such a construction similar to gauging ISO(1,3) in order to obtain General Relativity? In that case I would recommend the lecture notes/book by Van Proeyen on Supergravity :)
Related to Gauge theory with non-dynamical gauge field
1. What is gauge theory with non-dynamical gauge field?
Gauge theory with non-dynamical gauge field refers to a theoretical framework in physics that describes the interactions between matter particles and gauge fields that are not subject to their own dynamics. In other words, the gauge fields do not change or evolve over time, but they still play a crucial role in describing the behavior of matter particles.
2. How does gauge theory with non-dynamical gauge field differ from traditional gauge theory?
In traditional gauge theory, both matter particles and gauge fields are treated as dynamic entities and can change over time. In gauge theory with non-dynamical gauge field, the gauge fields are considered fixed and do not change, while the matter particles still interact with them.
3. What are some examples of gauge theories with non-dynamical gauge fields?
One example is the non-dynamical electromagnetic field in quantum electrodynamics, where the electromagnetic field is considered fixed and not subject to its own dynamics. Another example is the non-dynamical Higgs field in the Standard Model of particle physics, which is responsible for giving particles their mass.
4. What is the significance of studying gauge theory with non-dynamical gauge field?
Studying gauge theory with non-dynamical gauge field allows us to better understand the behavior of matter particles in the presence of fixed gauge fields. It also helps us to develop more accurate theoretical models and make predictions about the behavior of particles in different physical scenarios.
5. Are there any real-world applications of gauge theory with non-dynamical gauge field?
Yes, gauge theory with non-dynamical gauge field has many applications in modern physics, such as in understanding the behavior of particles in particle accelerators and developing advanced technologies like superconductors. It also has implications in fields like cosmology and astrophysics, where the behavior of matter particles in the presence of fixed gauge fields can help explain phenomena in the universe.
