- 5,844
- 551
Hello! This is regarding problem 10.4 in Wald. Let ##(M,g_{ab})## be a space-time, ##\Sigma_{t}## be a one parameter family of space-like hypersurfaces foliating the space-time, and ##n^{a}## the unit normal vector field to the space-like hypersurfaces. We have the induced metric ##h_{ab} = g_{ab} + n_a n_b## on each ##\Sigma##, which acts as a projection operator, taking space-time tensor fields to tensor fields over ##\Sigma##. We also have an induced derivative operator ##D_a## associated with ##h_{ab}## which is defined by ##D_{e}T^{a_1...a_n}{}{}{}_{b_{1}...b_m} = h_{e}{}{}^{f}h^{a_1}{}{}_{c_1}...h^{a_n}{}{}_{c_n}h_{b_1}{}{}^{d_1}...h_{b_m}{}{}^{d_m}\nabla_{f}T^{c_1...c_n}{}{}{}_{d_{1}...d_m}## where ##\nabla_{a}## is the regular space-time derivative operator. Finally, define the extrinsic curvature ##K_{ab}## of ##\Sigma## with respect to ##n^{a}## by ##K_{ab} = h_{a}{}{}^{c}\nabla_{c}n_{b}##.
So problem 10.4 is to show that the Gauss-Codacci equation ##D_{a}K^{a}{}{}_{b} - D_{b}K^{a}{}{}_{a} = R_{cd}n^{d}h^{c}{}{}_{b}## holds. I keep getting stuck near the end of the calculation and it's starting to get quite frustrating![Frown :frown: :frown:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
##D_{a}K^{a}{}{}_{b} = h_{a}{}{}^{c}h^{a}{}{}_{d}h_{b}{}{}^{e}\nabla_{c}K^{d}{}{}_{e} = h^{cf}h_{b}{}{}^{e}\nabla_{c}\nabla_{f}n_{e} + h^{c}{}{}_{d}h_{b}{}{}^{e}\nabla_{c}h^{df}\nabla_{f}n_{e}## and similarly ##D_{b}K^{a}{}{}_{a} = h_{b}{}{}^{c}h^{a}{}{}_{d}h_{a}{}{}^{e}\nabla_{c}K^{d}{}{}_{e} = h_{b}{}{}^{c}h^{ef}\nabla_{c}\nabla_{f}n_{e} + h_{b}{}{}^{c}h^{e}{}{}_{d}\nabla_{c}h^{df}\nabla_{f}n_{e}##. Now, ##h^{e}{}{}_{d}\nabla_{c}h^{df} = h^{e}{}{}_{d}n^{f}\nabla_{c}n^{d}## and ## h^{c}{}{}_{d}\nabla_{c}h^{df} = h^{c}{}{}_{d}n^{f}\nabla_{c}n^{d}## because ##\nabla_{a}g^{bc} = h_{ab}n^{b} = 0##.
Therefore, ##D_{a}K^{a}{}{}_{b} - D_{b}K^{a}{}{}_{a} = h^{cf}h_{b}{}{}^{e}(\nabla_{c}\nabla_{f}n_{e} - \nabla_{e}\nabla_{f}n_{c}) + h^{c}{}{}_{d}h_{b}{}{}^{e}n^{f}(\nabla_{f}n_{e}\nabla_{c}n^{d} - \nabla_{f}n_{c}\nabla_{e}n^d)##.
Using the Leibniz rule for ##\nabla_{a}## you can also put the equation in the form ##D_{a}K^{a}{}{}_{b} - D_{b}K^{a}{}{}_{a} = h^{cf}h_{b}{}{}^{e}(\nabla_{c}\nabla_{f}n_{e} - \nabla_{e}\nabla_{f}n_{c}) + h^{c}{}{}_{d}h_{b}{}{}^{e}n^{f}\nabla_{f}(n_{e}\nabla_{c}n^{d} - n_{c}\nabla_{e}n^{d})##.
As you can see, the final equation is antisymmetrized over ##e## and ##c## which, at face value, seems to be an issue because we want antisymmetrization over the indices on the space-time derivatives in order to get the Ricci tensor. I've tried everything but I can't seem to find a way to simplify the above equation any further. I tried using the fact that ##n^{a}## is hypersurface orthogonal, i.e. ##n_{[a}\nabla_{b}n_{c]} = 0##, in as many different ways as possible but nothing seemed to work. Plugging in ##h^{cf} = g^{cf} + n^{c}n^{f}## only seemed to make things worse so there must be a way to simplify it before having to plug in for ##h^{cf}##. All of the aforementioned issues apply to both forms of the equation written above. Does anyone have any hints / suggestions as to how I can show the desired result? Thank you very much in advance.
