Dev
- 11
- 3
- Homework Statement
- Please see image.
- Relevant Equations
- Nil.
The answer key shows option D is correct. But I think option C is also correct. Which option is correct here?
So, the field is not necessarily uniform on the Gaussian surface?Orodruin said:Only c is correct.
What makes d incorrect is the statement that the field is uniform on the surface.
Blindly? No. You should never trust anything blindly.Dev said:Can I trust this site blindly?
Can I trust you blindly, sir?Orodruin said:Also, PF, while great for getting questions answered, is not source material. It cannot fill the function of a textbook.
You shouldn't trust anything blindly, but you should be able to decide to what extent a source is reliable. PF has the advantage that if someone makes a mistake, someone else will probably notice.Dev said:Can I trust this site blindly?
Why is (a) incorrect?Orodruin said:Only c is correct.
You mean misread total electric "flex" as total electric "flux".PeroK said:a) and b) have to be read as "total" electric flex through the surface to be false!
Perhaps a flex is a flux line?kuruman said:You mean misread total electric "flex" as total electric "flux".![]()
Sounds about right for a flux line associated with the divergence. A line associated with the curl would be a circumflex.PeroK said:Perhaps a flex is a flux line?
Yes. Deposit all your money on my account ABC001954 in Banesco, Brickell Avenue 33091 .Dev said:Can I trust you blindly, sir?
The question pertains to Gauss’ law. The surface is closed and Gauss’ law relates to the total flux through a closed surface.kuruman said:Why is (a) incorrect?
You can have a surface element ##dA## (nobody said anything about integrating over a closed surface) with charges at some distance from the surface, one inside and the other outside, such that ##(\mathbf E_1+\mathbf E_2)\cdot \mathbf{\hat n}~dA \neq 0.## Both charges contribute to the electric flux through ##dA.##
