Gauss Law of Cube in non-uniform linear Electric Field.
In summary, Gauss's Law states that the electric flux through a Gaussian Surface enclosing a charge ##q_{enc}## is given by ##\phi=q_{enc}/\varepsilon_{o}## and that any external field does not contribute to the electric flux through the surface. It is concerned with the total flux through the whole closed surface and not just through opposite faces or parts of the surface. In the case of a non-uniform electric field, the net flux through the Gaussian Surface is 0 if there is no net charge enclosed, but this requires integration over all faces of the surface. The question about the direction of the electric field and its relation to the flux is more appropriate for the General Physics section.
Hijaz Aslam
66
Gauss's Law states that if a Gaussian Surface encloses a charge ##q_{enc}## then the electric flux through the Gaussian Surface is given by ##\phi=q_{enc}/\varepsilon_{o}## .
It also states that any external field does not contribute to the Electric Flux through the Gaussian Surface.
I am bit confused over there. If we have Gaussian Surface which is a cube placed in a non-uniform linear electric charge (by an infinite sheet for instance, and the Electric Field is parallel (anti-parallel) to the area vector of one of the faces (and the opposite face) ) the Flux through the two opposite faces of the cube does not cancel out. Is this true? What does the Gauss's Law actually states (along with conditions)?
Gauss' Law for electrical flux is concerned with total flux through the whole closed surface, not through the opposite faces/parts of the surface.
Yes of course not. I forgot to mention the direction of the Electric Field relative to the Cube. Please see the edited question.
Net flux through the gaussian surface indicates wether it encloses a net charge or not. No net flux means the surface doesn't enclose any net charge.
For example, if the gaussian surface is a cube placed in an external field, and if cube encloses no net charge, than flux through any two opposite pair of faces must cancel out regardless of direction of external field. BTW, your question is more appropriate for general physics subforum than here.
zoki85 - But in the case of non-uniform electric field it does not cancel out the flux of opposite faces, does it?
Can I somehow shift this question to the General Physics section?
In general case of nonuniform fields, total net flux is 0 (if qin=0), but you have to integrate over all the faces of the gaussian surface.
FAQ: Gauss Law of Cube in non-uniform linear Electric Field.
What is Gauss Law of Cube in non-uniform linear Electric Field?
The Gauss Law of Cube in non-uniform linear Electric Field is a mathematical equation that describes the relationship between electric fields and electric charges. It states that the flux of the electric field through any closed surface is equal to the charge enclosed by that surface divided by the permittivity of free space.
How is Gauss Law of Cube in non-uniform linear Electric Field applied?
This law is applied in situations where there is a non-uniform electric field, meaning that the strength of the electric field varies at different points in space. It can be used to calculate the electric field at a specific point by considering the distribution of charges around it.
What is the significance of Gauss Law of Cube in non-uniform linear Electric Field?
The Gauss Law of Cube in non-uniform linear Electric Field is an important principle in the study of electromagnetism. It allows scientists to analyze electric fields in complex situations and make predictions about the behavior of charges and electric fields.
Can Gauss Law of Cube in non-uniform linear Electric Field be used in all situations?
No, this law is only applicable in situations where the electric field is changing linearly with distance. If the electric field is changing exponentially or in a non-linear manner, this law cannot be used and other methods must be used to analyze the electric field.
How does Gauss Law of Cube in non-uniform linear Electric Field relate to Coulomb's Law?
The Gauss Law of Cube in non-uniform linear Electric Field is closely related to Coulomb's Law, which describes the force between two electric charges. The Gauss Law is a more general version of Coulomb's Law, as it can be used to calculate the electric field at any point in space, not just between two charges.
