PenDraconis
- 11
What is Ey, the y-component of the electric field at point P which is located at (x,y) = (0, -5 cm) as shown in the diagram?
$$E\oint dA = \frac{Q_{enclosed}}{\epsilon_0}$$
I'm confused on where the boundries of the shell lie, is it between the end of a and the end of b (thus making the shell have a width of b-a)?
If it IS the above, then we'd have to do analyze the problem with a Gaussian surface that ends at point P, located between the two.
We already know:
$$\rho = \frac{+Q}{\frac{4}{3}\pi r^3}$$
$$EA = \frac{Q_{enclosed}}{\epsilon_0}$$
$$E(4\pi r^2) = \frac{Q_{enclosed}}{\epsilon_0}$$
$$E(4\pi r^2) = \frac{\rho \frac{4}{3}\pi r^3}{\epsilon_0}$$
$$E = \frac{\rho r}{3\epsilon_0}$$
However, when I attempt to use the above expression, I'm not getting a correct answer. What am I doing incorrectly, I'm definitely confused on what "r" should I be using (i.e. is "r" the .05 m given to us in the problem or is, for some reason, the sphere with radius P minus the sphere with a radius of a)?
