Gauss' Theorem - Net Flux Out - Comparing two vector Fields
In summary, the net out flux of vector field F_1 for a unit sphere centered at (1,0,0) is greater than the net out flux of vector field F for a unit sphere centered at the origin. This can be explained by looking at the x term of the divergence, which is linear in x and will only have a positive contribution for the shifted sphere, resulting in a greater overall flux out. This is a qualitative answer based on the concept of Gauss' Law.
Master1022
611
117
Vector field [itex] F = \begin{pmatrix} x^2 \\ 2y^2 \\ 3z \end{pmatrix} [/itex] has net out flux of [itex] 4 \pi [/itex] for a unit sphere centred at the origin. If we are now given a vector field [itex] F_1 = \begin{pmatrix} x^2 \\ 2y^2 \\ 3(z+1) \end{pmatrix} [/itex], then how does the net out flux compare if we consider a unit sphere centred at (1,0,0) - is it bigger or smaller?
Gauss' Theorem
Hi,
I just have a quick question about a problem involving Gauss' Theorem.
Question: Vector field [itex] F = \begin{pmatrix} x^2 \\ 2y^2 \\ 3z \end{pmatrix} [/itex] has net out flux of [itex] 4 \pi [/itex] for a unit sphere centred at the origin (calculated in earlier part of question). If we are now given a vector field [itex] F_1 = \begin{pmatrix} x^2 \\ 2y^2 \\ 3(z+1) \end{pmatrix} [/itex], then how does the net out flux compare if we consider a unit sphere centred at (1,0,0) - is it bigger or smaller (than the 4 [itex] \pi [/itex] calculated earlier)?
This is the final part of the question and is worth very few marks, suggesting that I shouldn't need to do any calculations, but I am having trouble arriving at an answer intuitively. The whole question has been about Gauss' Law.
Method:
I am stuck and do not know what else to do beyond the realisation that [itex] \nabla \cdot \vec F_1 = \nabla \cdot \vec F [/itex].
Other initial thoughts that I have include:
- This sphere is completely in the +ve regions of the x-axis
- Some points of interest are on the surface of the new sphere: (0,0,0) and (x,y,z=-1)
I would appreciate any help.
Kind regards
I believe the y and z terms of ## \nabla \cdot F ## are going to give identical contributions in the volume integrals over the respective spheres. Do you agree?
Look next at the x term. For the sphere centered at the origin, this term is symmetric in the volume integral centered at the origin and it will vanish. How does it behave for the sphere centered at (1,0,0)?
It appears they are just looking for a qualitative answer, with no need to quantify it.
Finally, look again at the z term. It looks like that makes for a positive answer, with both cases the same. In fact that's where the ## 4 \pi ## comes from for the first case.
Thank you for your reply.
Yes, I agree about the y and z terms. For the x- term of the divergence, it is linear in [itex] x [/itex]. So am I correct in thinking that its contribution will be less for the shifted sphere? I think this might be the case because the 'more positive side' of the shifted sphere will give almost twice its original contribution, but the side nearest the origin will now give a -ve contribution as the divergence will oppose the normal surface vector. Hence the sum of these two contributions will be [itex] < 2 \times arbitrary [/itex] [itex] unit [/itex]
In the original case, the x component of [itex] \nabla \cdot \vec F [/itex] was alligned with the normal vector at both 'ends' of the sphere and thus giving [itex] = 2 \times arbitrary [/itex] [itex] unit [/itex]
With the ## \nabla \cdot F ##, you are doing a volume integral, (in order to compute a surface flux integral), and you don't have any direction in the volume integral. The first case, centered at the origin gets a minus for negative x. For the shifted case, the x is always positive. I do not agree with your answer that it will be less.
Likes hutchphd
Oh yes, I accidentally combined aspects of both integrals. Now I think I understand what you were originally saying - so the shifted version is all in the positive x-region, so there it only has a positive contribution to the volume integral. Hence, the total flux out will be greater.
From a surface integral perspective, could I pursue the following logic:
- There the 'more negative' side of the sphere will always have an opposition to the surface normal vector whether it is in the original or shifted sphere and this opposition will be the same amount.
- Moreover, for the shifted sphere, we have increased the 'more positive' side's contribution in proportion to [itex] x^2 [/itex] and thus the net flux out will be greater
- we have increased positive contribution whilst keeping the negative contribution the same.
Thanks for the help.
Likes Charles Link
This opposition (e.g. for the x term for the left side) is the same amount in absolute value by symmetry (as the right side) for the unshifted case. For this sentence I don't agree completely with how you stated it, but I think you understand the concept.
Likes Master1022
Related to Gauss' Theorem - Net Flux Out - Comparing two vector Fields
1. What is Gauss' Theorem?
Gauss' Theorem, also known as Gauss' Divergence Theorem, is a fundamental theorem in vector calculus that relates the flow of a vector field through a closed surface to the behavior of the field inside the surface.
2. What is net flux out?
Net flux out is a term used in Gauss' Theorem to describe the overall flow of a vector field through a closed surface. It takes into account both the inward and outward flow of the field through the surface, and can be calculated by taking the integral of the dot product of the vector field and the surface normal over the surface.
3. How is Gauss' Theorem used to compare two vector fields?
Gauss' Theorem can be used to compare two vector fields by calculating the net flux out of each field through a closed surface. If the net flux out of one field is greater than the other, it indicates that the field has a higher overall flow through the surface and is therefore stronger.
4. What is the significance of comparing two vector fields using Gauss' Theorem?
Comparing two vector fields using Gauss' Theorem allows us to understand the behavior and strength of the fields in a given region. It can also provide insights into the sources and sinks of the fields, as well as any changes in the fields over time.
5. Can Gauss' Theorem be applied to any type of vector field?
Yes, Gauss' Theorem can be applied to any type of vector field, as long as it is a continuous and differentiable function. This includes both conservative and non-conservative fields, making it a versatile tool in vector calculus.
