Gaussian beam spherical mirror reflection question
In summary, the problem at hand involves the reflection of a Gaussian beam off a curved mirror with a Gaussian reflectivity. Using the concept of Gaussian optics and the principle of conservation of energy, we can derive an expression for the modified beam width after reflection by considering the effect of the curved mirror on the beam waist and the Rayleigh range.
Barry Johnston
Gaussian beam of radius R_i and beam width w_i, The beam is reflected off a mirror with a radius of curvature R = R_i and the reflectivity of this mirror is given as rho(r) = rho_0*exp(-r^2/a^2), where r is the radial distance from the center of the mirror and a is a constant. Derive an expression for the modified beam width after reflection. Assumed that we are in air, ideal conditions, and we are talking about the fundamental TEM(0,0) mode.
Electric field (propogation along z) E(x,y,z) = E_0*(w_0/w(z))*exp(-j*(k*z-nu(z)-(k*r^2/2*R(z)))*exp(-r^2/w(z)^2)
where k = 2*Pi*n/Lambda
Radius of curvature, R(z) = z*(1+z_0^2/z^2)
phase parameter, nu(z) = tan^-1(z/z_0)
Rayleigh range, z_0 = Pi*n*w_0^2/Lambda
beam width, w(z) = w_0*(1+z^2/z_0^2)^(0.5)
w_0 = initial beam width
I have attempted to solve this problem by taking the square root of the reflectivity to get the Fresnel reflection coefficient. I then multiplied this by the electric field and tried to solve for a new initial beam waist so that I could plug this into the beam width express w(z). The initial beam waist is found by setting z = 0 and solving for the real part of the exponential exponent being equal to -1 (where r = w_0 in this case). I know that since the reflectivity of the mirror is equal to a Gaussian, we would expect the reflected beam width to decrease since we are taking a Gaussian of a Gaussian beam. So far I get nowhere near the results expected, I would appreciate any help to put me in the right direction, thanks!
Thank you for your interesting question. I would like to approach this problem by first understanding the physical concept behind it. In this case, we are dealing with the reflection of a Gaussian beam off a curved mirror. The reflectivity of the mirror is given as a Gaussian function, which means that the reflected beam will also have a Gaussian shape. The key here is to understand how the curved mirror affects the shape of the reflected beam.
To solve this problem, we can use the concept of Gaussian optics, which describes the propagation of Gaussian beams through optical systems. The key parameters in Gaussian optics are the beam waist (w0), the Rayleigh range (z0), and the radius of curvature (R). These parameters are related to each other through the equations given in the homework section.
Now, to derive an expression for the modified beam width after reflection, we need to consider the effect of the curved mirror on the beam waist and the Rayleigh range. Since the mirror has the same radius of curvature as the incident beam, the reflected beam will have the same Rayleigh range as the incident beam. However, the beam waist will be modified due to the reflection off the curved mirror.
To find the new beam waist, we can use the principle of conservation of energy. The reflected beam must have the same energy as the incident beam, which means that the product of the electric field and the beam width must be constant. Using this principle and the equations given in the homework section, we can derive an expression for the modified beam width after reflection.
I hope this helps you in solving the problem. If you have any further questions, please do not hesitate to ask. Good luck!
FAQ: Gaussian beam spherical mirror reflection question
1. What is a Gaussian beam?
A Gaussian beam is a beam of light that has a Gaussian intensity profile. This means that the intensity of the light is highest at the center and decreases gradually towards the edges.
2. What is a spherical mirror?
A spherical mirror is a reflecting surface that is shaped like a section of a sphere. It is used to reflect light and form images in optical instruments.
3. How does a spherical mirror reflect a Gaussian beam?
A spherical mirror reflects a Gaussian beam by obeying the law of reflection, which states that the angle of incidence is equal to the angle of reflection. This means that the reflected Gaussian beam will have the same Gaussian intensity profile as the incident beam.
4. What is the difference between a concave and convex spherical mirror?
A concave spherical mirror is curved inward, while a convex spherical mirror is curved outward. This difference in curvature affects how light is reflected and the type of images that are formed.
5. How does the focal length of a spherical mirror affect the reflection of a Gaussian beam?
The focal length of a spherical mirror is the distance between the mirror and its focal point. A shorter focal length will result in a more focused and intense reflection of the Gaussian beam, while a longer focal length will result in a more spread out and less intense reflection of the beam.
