MHB Gaussian Quadrature: isolated roots
The discussion focuses on the application of Gaussian Quadrature and the concept of isolated roots in weight functions. Isolated roots are defined as roots with multiplicity one, meaning they do not affect the derivative of the function in their vicinity. The weight function used in the example, $\sqrt{|x|^3}$, has one isolated root, which raises questions about potential issues when the weight function equals zero over an interval. Participants clarify that isolated roots are characterized by their lack of nearby roots, rather than their multiplicity. Understanding these concepts is crucial for correctly applying Gaussian Quadrature methods.
mathmari
MHB
In an exercise I have determined the Gaussian Quadrature formula and I have applied that also for a specific function.
Then there is the following question:
Explain why isolated roots are allowed in the weight function.
What exacly is meant by that? Could you explain that to me? What are isolated roots?
(Wondering)
Mathematics news on Phys.org
Hey mathmari!
Which weight function do you have? (Wondering)
Wiki lists $w_i = \frac{2}{\left( 1-x_i^2 \right) [P'_n(x_i)]^2}$ for the Gauss-Legendre quadrature on [-1,1], where $P_n$ are the normalized Legendre polynomials.
This weight function does not have roots. (Worried)
Anyway, I think an isolated root is a root with multiplicity $1$, which means that it's not a root of the derivative.
For instance $(x-3)^2$ has a root at $3$ with multiplicity $2$, meaning it is not an isolated root. (Nerd)
Anyway, if think an isolated root is a root with multiplicity $1$, which means that it's not a root of the derivative.
I had determined the formula $$\int_{-1}^1f(x)\cdot \sqrt{|x|^3}\, dx\approx \sum_{i=1}^nf(x_i)\cdot w_i=f(x_1)\cdot w_1+f(x_2)\cdot w_2$$ So the weight function in this case is $\sqrt{|x|^3}$ which has one root. (Thinking)
Does your calculation come from a method with a proof?
If so, is there any step where it would be a problem if the weight function had one or more isolated roots? (Wondering)
Edit: Just realized that a typical problem could be when the weight function would be zero on an interval.
That is, an isolated root is not about multiplicity. Instead it is about whether there's a neighborhood without other roots or not. (Blush)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
