Gauss's Law and Charges on Conductors
In summary, connecting a conducting wire from the outside of a hollow conducting sphere to ground will result in no electric field being measured outside the sphere due to the resulting net negative charge on the inside of the sphere.
emilyz228
A hollow conducting sphere has no net charge. There is a positive point charge at the center of the spherical cavity within the sphere. You connect a conducting wire from the outside of the sphere to ground. Will you measure an electric field outside the sphere?
I know that since the electric field inside of the conductor must be zero, that means the charge within the conductor must be zero. This means that there is a evenly distributed negative charge on the inner surface of the conductor, yielding a net charge of zero. The outer surface of the sphere then must have a positive charge in order for the sphere to have no net charge.
My question is then once the ground wire is connected to the outside of the sphere, electrons will flow from ground to the sphere to neutralize the positive charge on the outside. But what happens to the inside of the sphere? Nothing? Does this mean that once the conducting wire is connected from ground to the outside of the sphere that the sphere will then have a net negative charge?
But I thought that the electric field outside the sphere has to be zero due to the no net charge?No, you will not measure an electric field outside the sphere. When the ground wire is connected to the outside of the sphere, electrons will flow from ground to the sphere to neutralize the positive charge on the outside. This creates a net negative charge on the inside of the sphere, which cancels out the positive charge at the center of the cavity. This means that the sphere will have no net charge, and thus there will be no electric field outside the sphere.
Related to Gauss's Law and Charges on Conductors
What is Gauss's Law?
Gauss's Law is a fundamental law in electromagnetism that relates the electric flux through a closed surface to the net electric charge enclosed within that surface.
How is Gauss's Law used to calculate the electric field on a conductor?
Gauss's Law can be applied to a conductor to determine the electric field at any point on its surface. The electric field inside a conductor is zero, and the electric field at any point on the surface is perpendicular to the surface.
What is the significance of a conductor having an equal distribution of charges on its surface?
Conductors have the property of having equal distribution of charges on their surface. This means that the electric field inside a conductor is zero, and the charges on the surface will rearrange themselves to cancel out any external electric field.
How does the shape of a conductor affect its electric field?
The shape of a conductor affects its electric field as it determines the distribution of charges on the surface. The electric field is stronger at points of higher curvature and weaker at points of lower curvature.
Can Gauss's Law be applied to non-conducting materials?
No, Gauss's Law can only be applied to conducting materials as it relies on the property of equal charge distribution on the surface of a conductor. Non-conducting materials do not exhibit this property.
