Gauss's Law and the permittivity of free space
In summary, the permittivity of free space is a unit-conversion factor in the SI system, and in natural units it is equal to the permeability of free space. It is necessary to keep track of this constant when using the international system of units. When placing a charge in a dense medium, the electric field is typically weaker due to the polarization of the atoms or molecules in the medium. This effect is described by the macroscopic field and the constitutive constant \epsilon.
Jimmy87
686
Hi, could anyone help me understand the permittivity of free space in Gauss's Law:
[itex]\Phi[/itex] = q/[itex]\epsilon[/itex]0
If you consider a point charge in a box then I think it tells you how easy it is to establish an electric field in free space. But what happens if the medium is not free space - say you put the charge in a box with a dense medium. Does this mean an electric field will be harder or easier to establish? So does epsilon zero give you the situation where the electric field or flux will be the highest?
Thank you for any help offered.
First of all the socalled permittivity of the vacuum is a unit-conversion factor in the SI. In more natural systems of units [itex]\epsilon_0=\mu_0=1[/itex] and you put appropriate factors [itex]c[/itex] or [itex]1/c[/itex] into the Maxwell equations (sometimes with factors [itex]4 \pi[/itex]), leading to rationalized and usual Gaussian units. E.g., in rationalized (Heaviside-Lorentz) units, the Maxwell equations (in a vacuum) read
[tex]\vec{\nabla} \times \vec{E}+\frac{1}{c} \partial_t \vec{B}=0, \quad \vec{\nabla} \cdot \vec{B}=0,[/tex]
[tex]\vec{\nabla} \times \vec{B} - \frac{1}{c} \partial_t \vec{E}=\frac{1}{c} \vec{j}, \quad \vec{\nabla} \cdot \vec{E}=\rho.[/tex]
For the usual Gaussian units you simply mulitply the sources on the right-hand side of the latter two equations by [itex]4 \pi[/itex]. In these units the electric and the magnetic fields have the same dimension as it should be from a relativistic point of view. This is somewhat cumbersome to use in everyday life of an electrician, because the units of usual currents become somewhat unhandy to handle.
Thus one has invented the international system of units, where you always have to carefully keep track of the constants [itex]\epsilon_0[/itex] and [/itex]\mu_0[/itex]. There is, fortunately, only one arbitrary factor in this choice of units, because one necessarily has [itex]c=1/\sqrt{\mu_0 \epsilon_0}[/itex].
If you put a charge in a dense medium you have to consider the reaction of this medium to the electric field of this charge. Take a non-conducting di-electric. It consists of a lot of atoms or molecules, which themselves are build of an atomic nucleus (atomic nuclei) and surrounding electrons, bound to the nucleus. Then the electric field of the added charge causes the negatively charged electrons to be shifted a bit relative to the positively charged nuclei, which leads to a little (additional) polarization of the atoms or molecules and thus the whole medium. Usually the electric fields of such external sources are weak compared to the electric fields binding the electrons and atomic nuclei together. This implies one can do "linear-response theory", i.e., you can assume that the polarization is linear to the extra "external field" brought into the system by the additional charges. Finally you introduce the macroscopic field [itex]\vec{D}=\epsilon \vec{E}[/itex] and lump all the complicated interactions of the fields and the interactions of the extra charges + charges constituting the medium on average to a consitutive constant [itex]\epsilon[/itex]. Then [itex]\vec{\nabla} \cdot \vec{D}=\rho,[/itex] where [itex]\rho[/itex] is the averaged distribution of the additonally brought in charges.
For an excellent introduction to this relation between the fundamental "microscopic" Maxwell equations with the "macroscopic" Maxwell equations and the constitutive relations, see
J. Schwinger, Classical Electrodynamics
Usually, the electric field is weaker inside a medium. This is because the charges in the medium move around to cancel out the free charge (to some extent). Of course, outside the medium, the electric field goes back up to full strength (since the medium develops a charge around the outer layer which exactly matches the charge that was canceled out in the interior).
Related to Gauss's Law and the permittivity of free space
What is Gauss's Law?
Gauss's Law is a fundamental law in electromagnetism that relates the electric flux through a closed surface to the charge enclosed by that surface.
How is Gauss's Law mathematically represented?
Gauss's Law is represented by the equation ∮SE⃗·dA⃗ = Qenc0, where ∮SE⃗·dA⃗ is the electric flux through a closed surface S, Qenc is the charge enclosed by that surface, and ε0 is the permittivity of free space.
What is the permittivity of free space?
The permittivity of free space, denoted by ε0, is a physical constant that represents the ability of a vacuum to permit the passage of electric fields. Its value is approximately 8.854x10-12 F/m.
How does the permittivity of free space affect electric fields?
The permittivity of free space plays a crucial role in determining the strength of electric fields. A higher value of ε0 means that electric fields can penetrate more easily through a given material, while a lower value indicates that the material is more resistant to the passage of electric fields.
What are some real-world applications of Gauss's Law and the permittivity of free space?
Gauss's Law and the permittivity of free space are used in various applications, such as designing electronic circuits, calculating the capacitance of a capacitor, and understanding the behavior of electric fields in different materials. They are also important in the study of electrostatics and electromagnetism in physics and engineering.
  • Classical Physics
  • Electromagnetism
  • Classical Physics
  • Classical Physics
