Gauss's law -- Integral form problem
In summary, the problem involves calculating the variation of electric field with radius inside the electron cloud of a hydrogen atom in its quantum mechanical ground state. This can be done using Gauss's law in integral form, which requires determining the net charge enclosed by a spherical surface at a given radius. This involves taking the integral of the charge density with respect to the charge element dq from 0 to r.
jerryfelix30
The effective charge density of the electron cloud in a hydrogen atom in its quantum mechanical ground state turns out to be given by pnot(e^-(r/rnot)), where pnot is a negative constant (the clouds charge density at r=0) and rnot is a constant (rnot=0.025nm). Use gauss's law in integral form to calculate directly how E varies with r inside the electron cloud. Remember that there is a proton at r=0! Express your result in terms of the protons charge q.
Gauss's law= E dot dA=q(enclosed)/epsilon not
Q enclosed is the net charge enclosed in the shape and epsilonnot is the permittivity constant
Problem Statement: The effective charge density of the electron cloud in a hydrogen atom in its quantum mechanical ground state turns out to be given by pnot(e^-(r/rnot)), where pnot is a negative constant (the clouds charge density at r=0) and rnot is a constant (rnot=0.025nm). Use gauss's law in integral form to calculate directly how E varies with r inside the electron cloud. Remember that there is a proton at r=0! Express your result in terms of the protons charge q.
Relevant Equations: Gauss's law= E dot dA=q(enclosed)/epsilon not
The shape is a sphere so area is 4pi r^2
Ex4pir^2=q/epsilonnot
E=q/4pir^2(epsilonnot)
You need to rethink what ##q_{enclosed}## is if your Gaussian surface is inside the charge distribution. If you have a shell of radius ##r## inside the cloud, what fraction of the electron charge ##e## is enclosed by this shell? Hint: An integral is required.
So you have to take the integral from 0 to r for the charge density with dq?
Yes.
Related to Gauss's law -- Integral form problem
1. What is Gauss's law in its integral form?
Gauss's law in its integral form is a fundamental law in electromagnetism that relates the electric field at a point to the net charge enclosed by a closed surface surrounding that point.
2. How do you use Gauss's law to solve problems?
To solve problems using Gauss's law, you first need to identify the symmetry of the problem to determine the direction and magnitude of the electric field. Then, you need to choose an appropriate Gaussian surface and calculate the electric flux through that surface. Finally, you can use the equation Q = ε0ΦE to relate the charge enclosed by the surface to the electric flux, and solve for the unknown variable.
3. Can Gauss's law be applied to any closed surface?
Yes, Gauss's law can be applied to any closed surface, as long as the surface encloses the point where you want to calculate the electric field and the charge distribution is known or can be easily determined.
4. How does Gauss's law change in the presence of dielectric materials?
In the presence of dielectric materials, the electric field is reduced by a factor called the relative permittivity (εr). This means that in the integral form, the equation becomes Q = εrε0ΦE, where ε0 is the electric constant.
5. What are some practical applications of Gauss's law in integral form?
Gauss's law in its integral form has many practical applications, including calculating the electric field inside and outside of charged conductors, determining the electric field due to point charges or charged spheres, and analyzing the electric field in capacitors and other electronic devices. It is also an important tool in understanding the behavior of electromagnetic waves and their interaction with matter.
