Gauss's Law with non-uniform E-field
In summary: So anyways...2\pi l\int_{0}^{r} re^{ar} dr = 2\pi l \frac{e^{ar} (ar - 1) + 1}{a^2}\vec{E} = \frac{1}{\epsilon_0 r}\frac{e^{ar} (ar - 1) + 1}{a^2}Good. (If you want to express it as a vector, include a unit vector to show the direction.)In summary, the electric field from the center of the axis is zero for a long cylindrical object with a non-uniform charge density.
  • #36
Actually a better question would be, why wouldn't it be different?
  • #37
When inside the charged sphere, as r changes so does the total charge contained within r. But once you are outside of the sphere, the total charge remains fixed.
  • #38
Why? Shouldn't it get weaker?
  • #39
Someone come back
  • #40
Shouldn't what get weaker? (If you're responding to my last post, realize that I was talking about charge not field strength.)
  • #41
Well the density is non-uniform
[tex]\rho = \frac{Q}{V}[/tex]
Volume can't really change so
[tex]\rho\; \alpha \;Q[/tex]
so as radius goes up, density goes down and since they are proportional, charge drops?
  • #42
I have no idea what you're talking about.
Within the sphere, obviously the total charge within your Gaussian sphere increases with radius; Outside the sphere, there's no additional charge so the total charge remains fixed.
  • #43
[tex]Q_{en} = \int \rho dV[/tex]
I am going to take a while shot at this one. Since we are looking at r > R, that means we only care about the field r > R
I think it would be
[tex]Q_{en} = \int_{R}^{r} \rho dV[/tex]
But r > R not greater or EQUAL to. In other words, even though our Gaussian surface encloses the whole surface, it only cares about outside of r > R
  • #44
flyingpig said:
I think it would be
No. The relevant charge is everything contained within the Gaussian surface. Since the charge only extends to R, we have (for a Gaussian surface with r > R):
[tex]Q_{en} = \int_{0}^{R} \rho dV[/tex]
  • #45
But [tex]Q_{en} = \int_{0}^{R} \rho dV[/tex] is for a Gaussian surface that has radius R.
WOuld it be...
[tex]Q_{en} = \int_{0}^{R} \rho dV + \int_{R}^{r} \rho dV[/tex]
That includes inside and outside!?
EDIT: wait, that's no different from my first integral then...
EDIT2: nvm, you are right. My other integral encloses no charge because from R to r, it is just space. I keep thinking my integral is summing field, not charge.
  • #46
wait would the integral change if the density was uniform?
  • #47
Actually I should show you the final answer first to repay your time you put into helping me
[tex]2\pi l\int_{0}^{R} re^{ar} dr = 2\pi l \frac{e^{aR} (aR - 1) + 1}{a^2}[/tex]
[tex]\oint \vec{E} \cdot d\vec{A} = 2\pi l \frac{e^{aR} (aR - 1) + 1}{\epsilon_0 a^2}[/tex]
[tex]\vec{E} = \frac{e^{aR} (aR - 1) + 1}{\epsilon_0ra^2} \hat{r}[/tex]
