Gcd(m, n)=1 implies Zmn isomph to Zm x Zn
  • Thread starter Thread starter ArcanaNoir
The discussion revolves around proving that if m and n are relatively prime, then the group \(\mathbb{Z}_{mn}\) is isomorphic to \(\mathbb{Z}_m \times \mathbb{Z}_n\). The key points include demonstrating that the mapping \(\theta\) preserves operations and is both one-to-one and onto. Participants highlight the importance of the relative primality of m and n in establishing that the kernel of \(\theta\) contains only the identity element. The challenge of proving onto is addressed by noting that both sets have the same number of elements, which supports the isomorphism. Overall, the conversation emphasizes the need for clarity in definitions and reasoning throughout the proof process.
ArcanaNoir
show that if m, n are relatively prime, that is, greatest common divisor of m and n is 1, then \mathbb{Z} _mn \approx \mathbb{Z} _m \times \mathbb{Z} _n
I need to show that \theta is operation preserving, and I need to show that it is one to one and onto.
For theta, \theta ([a]_{mn} + <b>_{mn}) = \theta ([a+b]_{mn})=([a+b]_m,[a+b]_n)= </b>
([a]_m+<b>_m,[a]_n+<b>_n)=([a]_m,[a]_n)+([b)_m,<b>_n)= \theta ([a]_{mn}) + \theta (<b>_{mn}) </b></b></b></b>
Did I assume anything I shouldn't have there?
I'm going to consult my notes about proving 1-1. going to try the kernel thing.
As for onto, how do I show that?
I'm concerned that I haven't used the fact that m, n are relatively prime.
Hi Arcana!
You assumed your definition of theta, which I have to deduce from your work now.
Beyond that your proof of the preservation of the operation is correct.
So what's left is to proof that theta is 1-1, for which you need that m and n are relatively prime.
The definition of theta was given in a previous problem. I'm just tired of typing latex. Guess I need more practice so I'm not so slow at it.
going to consult notes about kernel thingy now for 1-1, but what about onto?
How many elements does each set have?
Are they the same?
I'm not sure what your kernel thingy is, but if you can say each element is mapped onto a different element, you can deduce "onto" by the fact that each set has the same number of elements.
difficulty:
theta is 1-1 iff ker(theta)= {e_Z_mn}
\theta ([a]_{mn})=([0]_m,[0]_n) \Rightarrow
m \mid a \wedge n \mid a \Rightarrow
a=km \wedge a=jn
I know that being relatively prime is the reason a must =mn but I'm not sure why, so I don't know what to say next.
You have n|a.
So from a=km, you know that n|(km).
Since n does not have any common factors with m, it must be that n|k.
This means that k=i n.
And in turn that:
a=km=(in)m=i(mn)
What is i? 1? And why does k=in? Sorry I'm being dense here.
Since n|k, there must be a number i such that k=in.
Not dense, I know how hard it is to follow other people's reasoning in algebra.
The trick is to set up your own reasoning.
I just hope my comments can help you in your reasoning.
