Gear Ratio in Bicycles using Rotational Motion
In summary: Similarly , if the bike is going too fast , the chain will start to 'skip' over the gears and the bike will eventually come to a halt .... This is because the ground pushes back on the bike tire and the bike can't keep up with the ground's force .... So the bike comes to a halt because the ground pushes back on the tire and the bike can't keep up with the ground's force ....When angular velocity of the back wheel increases , the wheel gains a tendency to slip on the ground . Friction opposes this tendency of relative motion by increasing - this causes acceleration of the wheel's center of mass , causing increase in velocity of the Com , thus making net velocity of point in contact with ground zero , thus preventing relative
andyrk
658
When we change the gears of the bicycle we are riding, we change the the disc we are currently at (which are located at the place where we pedal) to some other disc. This means the radius of the circular disc we were pedaling/rotating changes. So that means if we were rotating the disc with angular velocity ##ω##, if ##r## changes (radius of the disc) ##rω## changes. And that means the speed with with the chain which rolls over the disc, i.e. ##v = rω## changes. But how does that make the bike move faster with the same angular velocity we were providing it as before? If we want it to move faster, then the velocity of COM of the rear/front tire should increase, but how does changing gears do that?
andyrk said:
...the speed with with the chain which rolls over the disc, i.e. v=rωv = rω changes. But how does that make the bike move faster with the same angular velocity we were providing it as before?
What happens with the angular velocity of the back wheel, if the speed of the chain changes?
Okay..it increases too. But I still didn't get how that increases the speed of the bike? I think it is because of the force imparted by the ground on the rear tire, which happens because the rear tire pushes the ground back..so the ground pushes the tire front..giving it some acceleration. Which increases the velocity of the rear tire and as a result of the entire bike.
Also, if we stop pedaling why does the bike come to a complete halt after sometime? How can it be friction because friction is always acting in the direction of motion of the bike?
Air resistance , friction between parts of the cycle , and other stuff too ( Not sure what that other stuff may be , though ) .
How exactly does the rear tire apply force to the ground? It has a velocity at the bottom-most point..so how does it lead to applying a force?
No.
Friction.
A.T. said:
No.
Yes.
A.T. said:
Friction.
Friction is applied by the ground not by the rear tire. What I am saying is friction is a reaction force. What was the action force?
Both. There are two equal but opposite forces between tire and ground.
It doesn't matter which of the two forces you call "action" and which "reaction". They are both friction.
Okay, so I should ask: "How" does the rear tire apply a force on the ground?
How or Why ?
Both
When angular velocity of the back wheel increases , the wheel gains a tendency to slip on the ground . Friction opposes this tendency of relative motion by increasing - this causes acceleration of the wheel's center of mass , causing increase in velocity of the Com , thus making net velocity of point in contact with ground zero , thus preventing relative motion , and in this process causing increase in bike's speed .
If there is no slippage, then angular velocity and COM's linear velocity change simultaneously. So I don't see how you can tell which change is causing the other change. Seem arbitrary to me.
A.T. said:
If there is no slippage, then angular velocity and COM's linear velocity change simultaneously. So I don't see how you can say which change is causing the other change. Seem arbitrary to me.
Well the angular velocity increases with time , and so it must be causing simultaneously , the velocity of Com to increase too .
Take a rubber ball , spin it and drop on the ground . It would first slip and then eventually , start to roll . What would you say is the mechanism/cause for this ?
You could just as well say:
The velocity of Com increases with time, and so it must be causing simultaneously , the angular velocity to increase too .
But here the angular velocity would decrease, the opposite of the case above. And a bike isn't dropped with spinning wheels, so what does it have to do with an accelerating bike?
So changing the gear doesn't cause a direct increase in angular velocity of the wheel ?
My point here is that friction , in the ball's case is opposing the relative motion and therefore causing an increase in ball's horizontal velocity ; and the only difference in the case of the ball and wheel is that the ball had slipping in the start and hence friction opposed angular velocity , in the case of the wheel it would not , it would merely increase the Com's velocity .
Switching gears doesn't necessary change the bike speed, which (assuming no slippage) determines the angular velocity of the wheel.
Qwertywerty said:
My point here is that friction , in the ball's case is opposing the relative motion...
You can (and usually do) accelerate a bike without any relative motion at the contact (slippage).
No - I don't think so either . But the case the OP talks about involves increasing the speed of the bike .
That is what I have been saying all along . What I've been trying to do is give the reason for this .
Locally the "reason" is static friction. Globally the "reason" is simply that the equations of motion say so, given certain boundary conditions.
Would you care to explain how this works ?
A.T. said:
Also several thread on this forum discuss this.
I know how friction works , I'm asking what the mechanism is in this case - Angular velocity increases , so ...
It's your claim, not mine, that the increase of angular velocity is somehow a fundamental cause that triggers the rest.
Ok then . Do have some explanation to share ?
Not beyond what I already wrote in post #20.
You've got things backwards here. Friction acts to retard motion. It may not be the friction you are thinking of in the contact between the tire and the ground, but what about in the wheel and axle bearings?
I don't get why this question keeps coming up. People seem to have a tendency to way overthinking what a bike does.
Changing gears (on anything) does not automatically increase the speed of the device. The thing that changes almost instantly is the rpm of the motor (for a bike, your legs).
Now, if you gear-up, slowing down your legs, but reducing your mechanical advantage (less torque transmitted to the wheels, fractionally), how does this help you accelerate...?
How does a faster spinning rear wheel generate more push from the ground?
Who says it does?
  • #31
If it doesn't then why does changing gears make the rear wheel go faster (COM)?
  • #32
It doesn't necessarily.
  • #33
Then what does changing gears even do?
  • #34
It changes the ratios of angular velocities and torques, between back wheel and pedals.
  • #35
Which would do what?
