SevenToFive
- 56
- 3
Working on a project at work for backlash in a gearbox. I need to know the amount of backlash in arc minutes that this particular ratio has. Wondering if my approach is on the right path.
So can calculate the loose tolerance by the amount of end play in the input shaft and output shaft, add the input tolerance and output shaft tolerance together, divide by the gear pitch diameter, then divide by 2 for the radius. That should give me the sine of the degree, if I take the arc sine (sin^-1) of that value it will give me the degrees that I can multiply by 60 to get arc minutes. Does my approach sound correct?
Thanks for the help.
