WK95
- 139
- 1
The mechanism that operates the load/unload tray for holding the disk in a tabletop Blu-ray player uses nylon spur gears, a rack, and a belt drive. The gear that meshes with the rack has a module of 2.5 mm. The gears have the numbers of teeth indicated, and the two sheaves have diameters of 7 mm and 17 mm. The rack is connected to the tray that holds the disk. For the tray to move at 0.1 m/s, how fast must the motor turn?
\omega_{4}=\omega_{5}\\
\omega_{2}=\omega_{3}\\
d_{1} \omega_{1} = d_{2} \omega_{2} \\
\omega_{2} = \frac{\omega_{1}d_{1}}{d_{2}} \\
N_{4} \omega_{4} = N_{3} \omega_{3} \\
N_{4} \omega_{5} = N_{3} \omega_{2} \\
N_{4} \omega_{5} = N_{3} \frac{\omega_{1}d_{1}}{d_{2}} \\
\omega_{1}=\frac{N_{4}\omega_{5}d_{2}}{N_{3}d_{1}} \\
I know that the module of the gear that meshes with the rack is 2.5[mm] so the module of the rack must also be 2.5[mm].
v=0.1[m/s]=0.1[\frac{m}{s}] \times 60[\frac{s}{min}]= 6[\frac{m}{min}] \\
v=6 [\frac{m}{rev}][\frac{rev}{min}] = 6[\frac{m}{rev}][rpm] \\
I need help from here.
Also, why is the units of the module [mm] and not [mm/teeth]? The formula for it is 2r/N
