General Chemistry Pressure and Rate laws
In summary, a study was conducted to determine the kinetics of the decomposition of phosphine at 950 K. The rate constant was found to be 0.027 s-1.
ElectronicError
The kinetics of the decomposition of phosphine at 950 K
4PH3 (g) -> P4 (g) + 6H2 (g)
was studied by injecting PH3(g) into a reaction vessel and measuring the total pressure at constant volume.
P total (Torr) Time (s)
100 0
150 40
167 80
172 120
What is the rate constant of this reaction?
PV = nRT
rate = k[PH3] ^n
Do I need to find the reaction order with respect to PH3 before finding the rate constant? I am lost.
Yes, you need to find the reaction order. But to do that, you need to relate the change in total pressure to the change in the number of mol/L of PH3. If at some time, t, there are some n moles of PH3 consumed, then what is the net change in the total number of moles of gas in the container?
Also, you've written the differential form of the n'th order rate law. Can you collect the terms, integrate it and write the expression for the concentration of PH3 as a function of time (and the initial concentration)?
Thanks for your help. This is what I have done so far, but it is still wrong.
ln[(PPH3)t / (PPH3)o] = -kt
Ptotal = PPH3 + PP4 + PH2
PPH3 = Po - PP4
PH2 = 6PP4
Ptotal = (Po - PP4) + 6PP4 + PP4
Ptotal= Po + 6PP4
PP4 = (Ptotal - Po) / 6
PPH3 = Po -PP4 = Po - [(Ptotal-Po) / 6]
Po = 100 torr
Pt= 100 - [(150-100) / 6] = 91.666 torr
ln0.91666 = -k * 40s
k = 0.0022
The correct answer is k=0.027 s-1
This is only true for n=1, and is not the correct equation for n != 1. You need to figure out the order of the reaction rate; you can't assume it is 1.
For n not 1, you have:
[tex]dA/dt = -kA^n \implies A^{-n}dA = -kdt \implies A^{1-n} - A_0^{1-n} = -k(t - t_0)[/tex]
PPH3 = Po - PP4
PH2 = 6PP4
Ptotal= Po + 6PP4
Not sure I follow what you're doing here. For every 4 moles of PH3 consumed there are 7 moles of products produced, resulting in a net change of +3 moles (for every 4 moles of PH3 consumed). So the decrease in partial pressure of PH3 is 4/3 of the increase in total pressure over any interval of time.
So, for instance, during the first 40s, since the p(tot) increases by 50 torr, p(PH3) must decrease by 50*4/3 torr. Using this method, you can translate the table for p(tot) into a similar table for p(PH3).
Write down the values in this new table and plug them into the general equation for the n'th order rate law (above) to find k and n.
Note that the above rate equation only applies if n is not 1. It is actually prudent to first check if n=1 works.
PS: I just checked. It is first order; so you can indeed use the rate equation you used in post #3, only you need to use it on the new table of numbers.
I think this problem can be done by substituting the pressure and time variables in the concentration-rate constant equations for various ordered reaction The equation are founsd as :
r = -d[A]/dt
r = k[A]^n n - order of reaction.
equating
kdt = d[A]/[A]^n. Integrate (with limits c0 - c initial and final concentration, and 0 - t) to find equation for 1st, 2nd, 3rd... order reactions.
Substitute the given data in equations 1 by 1 till constant value of k for all pair of pressure values is obtained. This constant value gives the real k and n the order.
Im not surwe of this method but i have seen similar problems that can be done this way.
This last bit is incorrect.
The given data does not refer to the concentration (or partial pressure) of one species - it is the total pressure in the vessel.
yeah u r right the data have to be converted into partial pressure of PH3 that would make my suggestion same as post #4. Sorry for the repetition.
FAQ: General Chemistry Pressure and Rate laws
1. What is the relationship between pressure and rate in a chemical reaction?
The rate of a chemical reaction is directly proportional to the pressure of the system. This means that as the pressure increases, the rate of the reaction also increases. This is because higher pressure results in more frequent collisions between reactant molecules, leading to a greater number of successful reactions per unit of time.
2. How do changes in pressure affect the rate constant of a reaction?
According to the Arrhenius equation, the rate constant of a reaction is inversely proportional to the pressure of the system. This means that as pressure increases, the rate constant decreases. This is because at higher pressures, the molecules are more closely packed together, making it more difficult for them to overcome activation energy barriers and react.
3. Can pressure affect the equilibrium constant of a reaction?
Yes, pressure can affect the equilibrium constant of a reaction. According to Le Chatelier's principle, an increase in pressure will shift the equilibrium towards the side with fewer moles of gas. This means that the equilibrium constant will change to reflect the new concentrations of products and reactants at the new pressure.
4. How does the ideal gas law relate to pressure and rate in chemistry?
The ideal gas law, PV = nRT, is a fundamental equation that relates pressure, volume, temperature, and number of moles of a gas. In chemistry, this equation is often used to determine the pressure of a reaction system. By manipulating the ideal gas law, we can also derive the relationship between pressure and rate in a chemical reaction (see question 1).
5. Can changes in pressure affect the rate of a reaction if the reaction is not in a gaseous state?
Yes, changes in pressure can still affect the rate of a reaction even if the reaction is not in a gaseous state. This is because pressure changes can affect the concentration of reactants, which in turn affects the rate of the reaction. For example, an increase in pressure can cause a liquid or solid reactant to dissolve more readily, leading to an increase in its concentration and therefore an increase in the reaction rate.
14K
22K
