General form of the solutions of polynomials
In summary: I was trying to say, and then you said that wasn't what you wanted! So, the answer is, the polynomial you are looking for is the "minimal polynomial" for that number, and it can be determined by using Galois theory. See the above link.In summary, the conversation discusses the general formulas for solving quadratic, cubic, and quartic polynomial equations, as well as the lack of general formulas for higher degree equations. The conversation then turns to the possibility of finding a general format for equations with radicals and eventually concludes that the polynomial equation for a given radical equation can be determined using Galois theory and the concept of minimal polynomials.
Jhenrique
685
I was studying a article that solves the cube and quartic equation in the inverse sense:
##x = \sqrt[3]{A} + \sqrt[3]{B}##
##x = \sqrt[4]{A} + \sqrt[4]{B} + \sqrt[4]{C}##
https://www.physicsforums.com/attachment.php?attachmentid=70239&stc=1&d=1401676309I found this relationship too:
https://www.physicsforums.com/attachment.php?attachmentid=70240&stc=1&d=1401676615
http://en.wikipedia.org/wiki/Scipione_del_Ferro#The_Solution_of_the_Cubic_EquationSo arise a question in my mind: if a polynomial can be a generalized format like:
##ax^2+bx+c##
##ax^3+bx^2+cx+d##
##ax^4+bx^3+cx^2+dx+e##
so can the solution have a generalized format too?
  • Equação cúbica e quártica.pdf
Mathematics news on Phys.org
The general formula for a quadratic equation is taught in high school. Given an equation of the form ##ax^2+bx+c=0## we have two roots:
$$x=\frac{-b\pm\sqrt{b^2-4ac}}{2a}$$
The general formula for the cubic equation is quite a bit more annoying. You can find it here: http://en.wikipedia.org/wiki/Cubic_equation#General_formula_for_roots
The quartic equation has an even more annoying general formula:
http://en.wikipedia.org/wiki/Quartic_equation#General_formula_for_roots
There are no general formulas for quintic or higher degree polynomial equations.
General formulas in this sense:
for quadratic: ##x = A + \sqrt[2]{B}##
for cubic: ##x = A + \sqrt[2]{B} + \sqrt[3]{C}##
for quartic: ##x = A + \sqrt[2]{B} + \sqrt[3]{C} + \sqrt[4]{D}##
or maybe:
##x = \sqrt[2]{A}##
Exist a valid, practice and correct pattern for the solutions?
Can you define your variables? What's wrong with the general formulas I posted?
I think this is what he means:
[itex]0=c_1+c_2x+c_3x^{1/2}+c_4x^{1/3}+c_5x^{1/4}+...[/itex]
Initially I was going to say: For a finite amount of terms (all the way up to [itex]c_{n+1}x^{1/n}[/itex], you can always multiply by [itex]x^n[/itex] to turn it into a normal polynomial.
I realized this is not the case though as you will still have fractional powers of x.
-edit
Actually, I am realizing that this is not what he means. Oh well, may as well leave my post here anyways.
As Matterwave said, there is no general solution to polynomials of degree 5 or greater. The pattern that you are noticing is most likely untrue as you get to higher order equations.
First, do you understand what I ask?
No, I don't know what you're asking. In the OP you asked:
##ax^2+bx+c##
##ax^3+bx^2+cx+d##
But I gave you the general formulas, and that's apparently not what you wanted.
Studying elementar algebra arise equations like: ##3x^5 - 2x^2 = x##, ##\frac{3x+2}{x^2-1}=0##, ##(x^{15}+3)(x^3+x^2+1)##, etc...
So someone thought: "those equations can be written more generically in the form:
##ax^2+bx+c##
##ax^3+bx^2+cx+d##
and the those equations will be called of polynomials."
Now studying the solutions of polynomials, arises a new format of equations involving radicals:
So, my question is: which would be the general format for equations with radicals?
##ax^2+bx+c##
##ax^3+bx^2+cx+d##
Wasn't this what Hertz posted? Or are you asking for the solutions to such equations?
Yes!
Matterwave, in his first response, gave links to general solutions to cubic and quartic polynomial equations.
You have also been told that there cannot be a general solution, in terms of radicals, to polynomial equations of degree 5 or higher (because there exist solutions to such polynomials that cannot be written in terms of radicals).
What more do you want?
I think what he wants is a general solution to the equations:
$$0=a+bx+cx^{1/2}$$
$$0=a+bx+cx^{1/2}+dx^{1/3}$$
$$0=a+bx+cx^{1/2}+dx^{1/3}+ex^{1/5}$$
etc.
My take: You can multiply by the lowest common denominator to obtain polynomial equations of degree LCD.
The first one you can turn into a cubic equation by multiplying by x^2. The second one you can turn into a polynomial of degree six by multiplying by x^6, and the last one you can turn into a polynomial of degree 30...
But I'm not sure if I'm adding or destroying roots or something by doing this procedure since the fractional powers give rise to branch cuts in the complex plane.
I want to find the polynomial equation ##p(x)## for a given ##x = \sqrt[4]{A} + \sqrt[4]{B} + \sqrt[4]{C}## or ##x = \sqrt[4]{A + \sqrt[3]{B + \sqrt[2]{C}}}##
In other words, given a "radical equation", I want to know which is the polynomial equation of kind ##ax^4+bx^3+cx^2+\cdots=0## for this "radical equation".
Ah, so you want this http://en.wikipedia.org/wiki/Minimal_polynomial_(field_theory )
Yeah... how find the minimal polynomial for:
and for:
FAQ: General form of the solutions of polynomials
1. What is the general form of the solutions of polynomials?
The general form of the solutions of polynomials is in the form of axn + bxn-1 + cxn-2 + ... + k = 0, where n is the degree of the polynomial and a, b, c, ... , k are constants.
2. How do you find the solutions of a polynomial?
To find the solutions of a polynomial, you can use different methods such as factoring, the quadratic formula, or the rational root theorem. These methods help you to break down the polynomial into simpler factors and solve for the unknown variable.
3. What is the difference between real and complex solutions of polynomials?
Real solutions of polynomials are values of the variable that result in a real number when substituted into the polynomial equation. Complex solutions, on the other hand, involve imaginary numbers and are typically in the form of a+bi, where a and b are real numbers and i is the imaginary unit.
4. Can a polynomial have multiple solutions?
Yes, a polynomial can have multiple solutions. The number of solutions is equal to the degree of the polynomial. For example, a quadratic polynomial (degree 2) can have up to two solutions.
5. How do you know if a polynomial has no solutions?
A polynomial has no solutions if all the terms cancel out when simplified or if there is a contradiction in the equation, such as 1=0. This can also be determined by graphing the polynomial and seeing if it intersects the x-axis at any point.
