Freixas
- 307
- 41
Let's start with a configuration in which one tube, A, splits into two, B and C. We can write the relationship
$$A_A v_A = A_B v_B + A_C v_C$$ When I first saw this formula (which was very recently), I wanted to solve for ##v_B## and ##v_C## given all other values. I can't of course. There are two variables and only one equation.
Let's say I closed off branch B, not at the junction, but somewhere down the tube. As I picture it, a compression wave would begin at the closed end, traveling at the speed of sound, to the junction. At that point, the velocity through branch B would be 0 and ##v_C## would be ## \frac { A_A } {A_C} v_A##
My question is whether there are general guides for the effects branch B might have on C (or vice versa). Let's say the two branches have the same cross-section areas. With a well designed junction, I might expect the flow to divide evenly between the two branches. Some distance down branch B, however, the tube narrows. If I simply looked at the flow through B as though it were an independent tube, I could calculate the speed of the flow through the narrower section. I am not sure that what is true in a B-only configuration applies to the A-B-C branching situation. In other words, perhaps some part of the flow would find it easier to switch from B to C rather then continuing down the narrow part of B.
Again, I'm trying to get a sense of whether there are any broad principles that can be applied. I am not looking for a detailed derivation or a precise formula. Simplifying assumptions are fine. For example, if an abrupt switch from wide to narrow creates turbulence that complicates things but a gradual transition does not, it's fine to assume a gradual transition. I would certainly assume that all flows have reached a steady state.
