General motion with constant speed
The magnitude of acceleration is the rate of change of speed, not the rate of change of velocity. The magnitude of d\vec{v}/dt is the rate of change of speed. The magnitude of \vec{a} is the rate of change of speed. The magnitude of d\vec{v}/dt is the rate of change of speed. Sorry :uhh: I meant to say "The magnitude of d\vec{v}/dt is the rate
Benzoate
422
A particle moves along any path in 3d space with constant speed. Show that its velocity and accelerations vectors must always be perpendicular to each other.[hint. Differentiate the formula v dot v = v^2 with respect to t.
possible equations: v=dr/dt=dr/ds*ds/dt, a=dv/dt=(dv/dt)t +(v^2/rho)n,
v=v*t where t is the unit tangent vector and n is the normal unit vector.
If a particle is moving in 3d space with constant speed, then the type of motion could be uniform circular motion and the acceleration is therefore equal to zero.
Probably, v dot v= v^2(x) + v^2(y)+ v^2(z) , x , y and z making up the dimensions of the 3-D plane; since the particle moves along a 3D plane. If the particle is in uniform motion, the position vector r probably is in polar coordinates: r= b*cos(theta)i + b*sin(theta)j and theta is equal to ut/b where u is the speed of the particle , b is the arc length and t is the time its traveled. Would I differentiate r and then plugged in dr/dt into the v dot v equation? I expect I also have to show that x hat times y hat or x hat times z hat or y hat times z is equal to zero, since the problem asks me to show that velocity and acceleration vectors are always perpendicular to each other.
Maybe the simplest solution is to show that v cross a = 0 since the acceleration of the particle is zero and therefore I would be done with the problem.
Just follow the hint! Take the derivative of both sides of:
[tex]\vec{v}\cdot\vec{v} = v^2[/tex]
Hint: If two vectors are perpendicular, what must their dot product be?
In uniform circular motion the acceleration is not zero. The acceleration is however orthogonal to velocity in uniform circular motion.
Try doing what the hint says first. You're making this way more complicated.
I'm having trouble determining what must be the derivative of v dot v. Would the derivative of v dot v be dv/dt*v+v*dv/dt=0 => 2*(dv/dt *v)=0?, since v is constant , therefore dv/dt=0 and thus 2*(dv/dt*v) must be zero, right?
The problem doesn't say anything about the particle being in uniform circular motion, problem only states that v is constant, and therefore if their is no change in velocity, the acceleration o the particle must be zero.
I was responding to the first paragraph in your attempt at the answer.
Anyway if the derivative of [itex] \mathbf{v} \cdot \mathbf{v} = v^2 [/itex] is almost as you have it.
[tex] \mathbf{v} \cdot \frac{d\mathbf{v}}{dt} + \frac{d\mathbf{v}}{dt} \cdot \mathbf{v} = 2v \frac{dv}{dt} [/tex]
As you have said the derivative of the speed must be zero if it is constant and if that is true how will the left hand side be made zero? Use Doc Al's hint above.
EDIT: oops made the same speed/velocity mistake :rolleyes:
Yes, but it's essential to distinguish the velocity (a vector) from the speed (a scalar). In this problem you are told that the speed is constant, not the velocity. All the v's on the left side of your equation stand for velocity, not speed. (See Kurdt's post.)
No, the problem said the speed was constant, not the velocity!
since the acceleration is zero, then v*dv/dt+dv/dt*v=2*v* dv/dt => v*0+0*v=2*v*0=> 0=0 which implies acceleration vector is perpendicular to velocity vector
No. The acceleration is NOT zero.
[tex]\vec{a} = \frac{d\vec{v}}{dt} \ne 0[/tex]
But:
[tex]\frac{dv}{dt} = 0[/tex]
But:
so if dv/dt ,without the vector, is not did acceleration, is dv/dt the magnitude of the acceleration?
Its the rate of change of speed. The question asks about the velocity and acceleration vector though. So how can the differentiated dot product side equal zero? Consider Doc Al's first hint.
Not exactly [itex]|d\vec{v}/dt|[/itex] would be the magnitude of the acceleration. If the acceleration is not 0 then its magnitude also cannot be 0. Doc Al is using v to mean [itex]|\vec{v}|[/itex] so dv/dt is the "derivative of the magnitude of the velocity" which is NOT the same as the "magnitude of the derivative of the velocity". The order is important!
No. v, without the vector sign, stands for speed. dv/dt is the rate of change of the speed.
FAQ: General motion with constant speed
What is general motion with constant speed?
General motion with constant speed refers to the movement of an object at a consistent rate, where the speed remains the same throughout the entire motion. It can be described as the object traveling at a steady pace without changing direction or velocity.
How is general motion with constant speed different from other types of motion?
General motion with constant speed is different from other types of motion, such as accelerated motion, because the speed of the object remains constant. In accelerated motion, the speed is constantly changing, either increasing or decreasing.
What is the formula for calculating speed in general motion with constant speed?
The formula for calculating speed in general motion with constant speed is speed = distance / time. This means that the speed of an object can be determined by dividing the distance it has traveled by the time it took to travel that distance.
Can an object have general motion with constant speed in a curved path?
Yes, an object can have general motion with constant speed in a curved path. As long as the speed of the object remains constant, it can travel in any direction, including a curved path.
What are some examples of general motion with constant speed?
Some examples of general motion with constant speed include a car traveling on a straight road, a plane flying at a constant altitude, and a person running around a circular track at a constant speed.
