General question about conservation of momentum
In summary, the Law of Conservation of Momentum states that momentum is always conserved in both elastic and inelastic collisions, as a consequence of Newton's Third Law. However, in a non-isolated system where external forces are present, the initial and final momentum may not be the same. It is important to consider all bodies involved in the system, as energy and momentum can be gained or lost to or from the outside world. In some cases, it may be necessary to adjust the system boundary to accurately apply the law.
vetgirl1990
85
Referring to the Law of Conservation of Momentum: How is momentum always conserved? In a non-isolated system, an external force causes a change in momentum, so that initial momentum isn't the same as final momentum. Wouldn't this constitute a situation where momentum is not conserved?
Or, is the Law of Conservation of Momentum specifically talking about how momentum is conserved in all collisions, whether elastic or inelastic?
1) Momentum is always conserved in both elastic and inelastic collisions. This is a consequence of Netwon's Third Law.
2) Kinetic Energy is also conserved in an elastic collision (but not in an inelastic collision).
3) Although momentum is always conserved, as you mention in your post, you need to consider all bodies involved. If an apple falls from a tree, then clearly the apple gains momentum. The momentum of the apple alone is not conserved. But, the Earth is subject to an equal an opposite gravitational force and is gaining equal and opposie momentum to the apple. The momentum of the apple-Earth system is, therefore, conserved.
Likes vetgirl1990
Don't we normally exclude the force (and kinetic energy) of Earth (unless the problem involves say, a collision with Earth and an asteroid) from problems, as the force that the Earth exerts on an object is so much smaller compared to applied forces? While technically you need to consider all bodies involved, for the sake of specific questions,
say one that involves finding the change in momentum of the falling apple, wouldn't we look at this system as isolated and therefore momentum not being conserved?
Yes. There are lots of problems where you don't make use of conservation of momentum. For example, in projectile motion problems. Often, however, you can solve problems by considering conservation of momentum in the horizontal direction, but not in the vertical direction (because you simply consider gravity as an external force). That's a neat trick that worth remembering.
The same is true for conservation of energy: it's always there. But if energy is dissipated to heat by an inelastic collision or by friction, then you lose Kinetic Energy from the system.
In short, total energy and total momentum are always conserved. But, sometimes they go outside the system you are considering. That's the key point always to consider: is my system losing or gaining energy or momentum to or from the outside world?
Likes vetgirl1990
Conservation of momentum only apples to closed systems (eg systems with no external forces). See..
https://en.wikipedia.org/wiki/Momentum#Conservation
If you find a situation where conservation of momentum appears to be broken it can be a clue that you may have drawn your system boundary in the wrong place. For example if you draw you system boundary just around the apple (post #2) then CoM appears to be broken. If you draw it around the apple and the Earth CoM holds true.
Likes vetgirl1990
FAQ: General question about conservation of momentum
What is the law of conservation of momentum?
The law of conservation of momentum states that the total momentum of a system remains constant unless acted upon by an external force.
How is momentum defined?
Momentum is defined as the product of an object's mass and velocity. It is a vector quantity, meaning it has both magnitude and direction.
Does the law of conservation of momentum apply to all types of collisions?
Yes, the law of conservation of momentum applies to all types of collisions, including elastic and inelastic collisions.
What is the difference between elastic and inelastic collisions?
In an elastic collision, the total kinetic energy of the system is conserved, while in an inelastic collision, some of the kinetic energy is converted into other forms of energy, such as heat or sound.
How does the conservation of momentum apply in real world situations?
The law of conservation of momentum is a fundamental principle in physics and applies to many real world situations, such as car crashes, rocket launches, and billiard ball collisions.
