General relationship for direction of E field at any given point
In summary, Ravenatic20 thinks that the direction of the electric field points perpendicularly towards or away from the line of charge. This follows from symmetry. Integration of the charge density using Coulombs law gets you your electric field. The right-hand-rule has no bearing on this, but it would if there was a line of current.
Ravenatic20
30
I was going through my textbook, Introduction to Electrodynamics, and I came across this question that puzzled me. The book is really great by the way, I would highly recommend it. No, this isn't a homework question, it just got me thinking.
For a finite line of charge (like a rod, for example), there should be a general relationship for the direction of the electric field no matter where point X is located with respect to the finite line of charge. What do you think this general relationship is?
Lets assume it’s a finite line of positive charge. I think of the electric field (E-field) always pointing outwards. So if you take a point X directly above the finite line of charge, say centered, it’s going to point up. But what relationship can we use to describe this?
I know you can take a bunch of little dq's and add them up, and the direction each one of those points as X can be added up as the direction of the E-field.
Can we incorporate the right-hand-rule with this? No rush to answer I was just curious.
Hi Ravenatic20! :smile:
Ravenatic20 said:
… I think of the electric field (E-field) always pointing outwards. So if you take a point X directly above the finite line of charge, say centered, it’s going to point up. But what relationship can we use to describe this?
I think you're trying to say that the direction of the field (which is what the question asks for) always points perpendicularly towards or away from the line.
(the right-hand-rule has nothing to do with this … there's no current in the line :wink:)
tiny-tim, what you say is only if the charge is on an infinite line, but Ravenatic was talking about a finite line of charge.
Anyway, this is a solvable problem. Ravenatic's method of integration is correct, just integrate up the charge density using Coulombs law and you get your E filed. I don't think the integration is trivial, but it can be done. BTW, the right-hand rule has no bearing on this, but it would be if the there was a line of current and you wanted to calculate the B-field.
It is, however, a prime candidate for far-field approximation. If we were to observe the fields at a distance r>>L, then the field should be fairly approximated as a point charge of
[tex]Q = \int_{-L/2}^{L/2} \rho(z)dz[/tex]
oops!
nnnm4 said:
tiny-tim, what you say is only if the charge is on an infinite line, but Ravenatic was talking about a finite line of charge..
oops! :blushing:
I somehow read "finite" as "infinite" :redface:
FAQ: General relationship for direction of E field at any given point
What is the general relationship for the direction of the electric field at any given point?
The general relationship for the direction of the electric field at any given point is determined by the direction of the force that a positive test charge would experience if placed at that point. The electric field points in the direction that a positive test charge would accelerate.
How is the direction of the electric field related to the direction of the electric force?
The direction of the electric field is directly related to the direction of the electric force. The electric field points in the same direction as the electric force, which is the direction that a positive test charge would accelerate.
Does the direction of the electric field change depending on the type of charge?
No, the direction of the electric field does not change depending on the type of charge. The electric field always points in the direction that a positive test charge would accelerate, regardless of whether the source charge is positive or negative.
How is the direction of the electric field affected by distance from the source charge?
The direction of the electric field is affected by distance from the source charge. As the distance from the source charge increases, the strength of the electric field decreases and the direction of the electric field becomes more radial, pointing away from the source charge.
Can the direction of the electric field be negative?
No, the direction of the electric field cannot be negative. The electric field is a vector quantity and can only have a magnitude and direction, not a negative value. However, the direction of the electric field can be opposite to the direction of the electric force, depending on the type of charge of the source charge and the test charge.
