General relativity and Higher dimensions
In summary: Intrinsic curvature is when the sum of the angles in a triangle is always 180 degrees. This can be seen in the case of a triangle drawn on a flat piece of paper, as well as on the surface of the earth. Intrinsic curvature is when the sum of the angles in a triangle is always 180 degrees.
lightseeker
Hi everyone , this is my first time here :)
My question is simple , if gravitation is basically a space distortion so it's fair to say that at least a fourth dimension exists , since a distortion must occur in higher dimension than the one of the concerned space .
Is it correct putting it like that ?
Thanks in advance.
Thanks in advance.
Gravitation only can't exist in spaces with 1 and 2 dimensions. The reason why a two dimensional space can't contain gravitation in it is that the Weyl tensor in 2D spaces always vanishes. For spaces of higher dimensions than 2, gravitation can be defined as in the theory of GR which lives in the 3 dimensional spaces with an extra time dimension.
AB
Welcome to PF!
Hi lightseeker! Welcome to PF! :smile:
No.
A space can be entirely self-contained, and still have what you call "distortion".
It does not need to be embedded in a higher-dimensional space.
From http://en.wikipedia.org/wiki/Curvature" …
There is a key distinction between extrinsic curvature, which is defined for objects embedded in another space (usually a Euclidean space) in a way that relates to the radius of curvature of circles that touch the object, and intrinsic curvature, which is defined at each point in a Riemannian manifold.
What you are describing is extrinsic curvature, but mathematicians and physicists are usually talking about intrinsic curvature. :wink:
No.
I think the OP does not ask whether the space can be distorted if there is no gravitational field or matter. (E.g. the surface of a 3-sphere.) The question is essentially about the dimensional aspects of spaces for which distortion chalks up to the presence of gravitation.
AB
AB
Yes, and I've said that curvature (or "distortion") can be intrinsic, meaning that eg a 3D space have have curvature without being part of a 4D space. :smile:
I am not a mathematician but trying to figure this out from an intuitive view point , I see extrinsic curvature is dealing with space itself , and intrinsic curvature dealing with structure of something inside space , but as I said it's just an intuition, so would you please explain this self-contained distortion ?
Intrinsic curvature just means that you can measure it without having to see or even hypothesize extra dimensions. For example, if the circumference of a circle is not exactly equal to [itex]2\pi r[/itex], then that's an indication of curvature.
When you say a circle or an other defined shape it becomes something in space , since I am initially talking about general space defined with N Dimensions.
Hi lightseeker! :smile:
lightseeker said:
… I see extrinsic curvature is dealing with space itself , and intrinsic curvature dealing with structure of something inside space …
Yes, except it's the other way round …
intrinsic curvature is in itself, extrinsic curvature is in something outside. :wink:
Would you give me a concrete example of an intrinsic curvature and show how it applies to space of certain dimensions using parallelism .
If you draw a triangle on a flat piece of paper, and measure the angles, their sum is 180 degrees. If you draw a triangle on the surface of the earth, the angles will not be 180 degrees, indicating that the surface of the Earth is curved. Drawing a triangle on the surface of the Earth is an operation confined to the surface that allows us to determine if that surface is curved or not - in this way, the curvature of the Earth's surface is intrinsically 2D, even though the Earth is embedded in 3D space.
In normal space, squared length are positive. The difference with spacetime is that some "squared lengths" are negative. Also, spacetime is 4D. To draw a triangle in spacetime, you can use light rays and freely falling particles.
Another example of an intrinsic curvature is http://mathworld.wolfram.com/GaussianCurvature.html" in GR is built on an isotropic and homogeneous line-element which again includes the Gaussian curvature [tex]k[/tex], and when [tex]k=1 [/tex] or [tex]-1[/tex] the metric always has an instrinsic uniform curvature which constructs an elliptical or hyperbolic spacetime, respectively. But on the other hand, you can have a space(time) that is not intrinsically curved as I can name the "cylinder" which can be easily embedded in an Euclidean 3-space. You can find a change of coordinates which brings the local coordinates of the cylinder to those of Euclidean 3-space and thus retrieving a flat space through a coordinate transformation.
AB
The Poincaré disc … an ordinary 2D disc with a curved (or "distorted") geometry … is an example of intrinsic curvature. :smile:
See http://en.wikipedia.org/wiki/Poincaré_disc_model" for details. :wink:
Let us consider your example which is a little bit intelligible , a triangle in an undisturbed flat piece of paper is an element of 2D space , and when it's seen from 3D view it's confined in a planar 2D space , but once you draw it on the surface of the Earth the curvature becomes evident not only from 2D view (measuring angles ) but also in third dimension since the triangle don't keep confined in the planar 2D space .
No! The metric of the surface of the Earth is dependent on two elements, basically the Earth radius [tex]r[/tex] and the latitude [tex]\theta[/tex]:
[tex]ds^2=r^2d\theta^2+r^2\sin^2(\theta)d\phi^2.[/tex]
This metric describes the geometry of the Earth surface and you can see it is completely 2D since the Earth is embedded in the 3D Euclidean space and thus its surface is a 2D submanifold! I think you are misunderstanding two implications of space and manifold by looking at the surface of the Earth as a space! It is a submanifold which has 2 dimensions or it can be described by two local coordinates, giving rise to it being 2D!
AB
As Altabeh says, the surface of the Earth is 2D, because you need only 2 coordinates to specify a point on it (eg. latitutde and longitude).
FAQ: General relativity and Higher dimensions
1. What is general relativity?
General relativity is a theory of gravity proposed by Albert Einstein in 1915. It states that the force of gravity is not a force between masses, but rather a curvature of spacetime caused by the presence of mass and energy. It has been confirmed by numerous experiments and is considered one of the most accurate and successful theories in physics.
2. What are higher dimensions?
Higher dimensions refer to spatial dimensions beyond the three dimensions (length, width, and height) that we experience in our everyday lives. In the context of general relativity, it is often used to refer to the possibility of additional dimensions that may exist beyond the three dimensions of space and one dimension of time.
3. How does general relativity explain higher dimensions?
In general relativity, higher dimensions are explained as additional dimensions of space that are curled up or compactified at a very small scale. This means that they are not directly observable, but their effects can be seen through the behavior of gravity in our three-dimensional world.
4. Are higher dimensions just a theoretical concept?
While the existence of higher dimensions is still a topic of debate among physicists, some theories, such as string theory, suggest that there may indeed be additional dimensions beyond the four we experience. However, these dimensions are thought to be so small that they cannot be observed directly.
5. How does the concept of higher dimensions impact our understanding of the universe?
The concept of higher dimensions has opened up new possibilities for understanding the fundamental laws of the universe and has led to the development of theories such as string theory, which attempt to unify the laws of physics. It also helps to explain phenomena such as gravity and the behavior of particles at the quantum level. However, the existence of higher dimensions is still a subject of ongoing research and debate.
