General Relativity: Components of ds^2
In summary, the metric is a map from coordinates in a tangent space to distances. The line elements are functions that relate the distance between two points in the manifold. In curved spacetime, the distance between two points is measured by integrating the line element over the path between the two points.
Jonsson
79
Hello there, suppose we take ##M## to denote the spacetime manifold. Suppose also that ## ds^2 = g_{\mu \nu} dx^\mu dx^\nu##. I have some confusions with regards to the metric and the line elements.
My main confusion is at which points in the manifold are ## ds^2## defined? Is it correct that if ## p \in M##, then it only makes sense to fix ## ds^2## for each tangent space ## T_pM##, or is it fixed for each ## v \in T_pM ##? More specifically:
(1) If there is some position dependent line element, such as the Schwartzschild line element, then ##g_{\mu \nu}= g_{\mu \nu}(t,r, \theta, \phi) ##. Are these ##(r, \theta, \phi)## the coordinates of some ##(t,r, \theta, \phi) \in M##, or are they the coordinates of some ## (t,r, \theta, \phi) \in T_pM ##?
(2) Are the differentials ## dx^\mu(x)## evaluated at each ## x \in M## or ##x \in T_pM##?
I'm not sure I can give you the full answer, but here's part of the answer.
In curved spacetime, you have the notion of distance only by integrating over the line element. In that sense, ##ds^2## is defined everywhere in spacetime, and relates to the continuous changes in distance along a path. In answer to question 1) you can calculate the distance along a path in spacetime by integrating ##ds## without any recourse to tangent spaces. The points and line element are defined therefore on the spacetime manifold.
The problem is how to define vectors. A vector has a length and a direction. But, if spacetime is curved, how do you define a vector of finite length in a given direction? This is the main motivation for tangent spaces. There is a tangent space at every point, and each coordinate system defines a set of basis vectors for the tangent space.
In answer to 2), you only have a single spacetime point in each tangent space, so the line element ##ds^2## doesn't apply in the tangent space.
I believe ds^2 is usually taken to be a scalar, which means it exists at a point regardless of the tangent space.
If one wanted to write a map from a pair of vectors to a scalar, which would depend on the tangent space, one would probably write ##ds \otimes ds##, where the operation ##\otimes## is the tensor product.
There's more potential for confusion without the square, ds could be a map from a vector to a scalar, or it could be just a scalar. I've seen various conventions, one is to write the scalar valued map from a vector (which is a dual vector) with a boldface d, ds, and the scalar in non-boldface, ds.
FAQ: General Relativity: Components of ds^2
What is the significance of the components in the ds^2 metric in general relativity?
The components in the ds^2 metric represent the various ways in which space and time can be distorted by the presence of mass and energy. They describe the curvature of spacetime, which is the fundamental concept in general relativity.
How are the components of ds^2 measured or calculated?
The components of ds^2 are typically calculated using the Einstein field equations, which are a set of differential equations that relate the curvature of spacetime to the distribution of matter and energy.
What do the different components of ds^2 represent?
The different components of ds^2 represent different aspects of spacetime curvature. For example, the tt component represents the time-time curvature, while the xy component represents the spatial curvature in the x-y plane.
Can the components of ds^2 change over time?
Yes, the components of ds^2 can change over time if there are changes in the distribution of matter and energy in the universe. This is known as the dynamic nature of spacetime in general relativity.
How does general relativity and the components of ds^2 relate to the theory of gravity?
In general relativity, gravity is not seen as a force between masses, but rather as a result of the curvature of spacetime caused by the presence of mass and energy. The components of ds^2 play a crucial role in describing this curvature and understanding the effects of gravity on the motion of objects in the universe.
