General Relativity Gravitation Calculations
In summary, the equation calculates the gravitational force between two masses, assuming they are not rotating and the masses are not too different in size.
cbd1
123
Question on calculating gravitation per General Relativity and the field equations:
I understand that Einstein's field equations describe spacetime. But I’m not sure of how they are used when evaluating gravitation. For example, the equations describe how spacetime is “curved” by a large object of mass. But how does it say how a smaller object will be influenced by that curvature.
If it could be broken down for me:
The equations are hard to make sense of. Say, if Earth (A) is the gravitational body with such and such mass, and the acceleration of a ball (B) with such and such a mass, in the air some (X) meters above the Earth’s surface, is effected by the curvature of spacetime (C?). Could you identify these characters in the field equations for calculating the force of gravity on a body?
To solve for the trajectory of a test particle in GR, one calculates the 'geodesic' along the proper manifold for the local-geometry.
The gravity determines the geometry of the manifold (local space-time), and the trajectory is simply the multidimensional equivalent of a straight-line (a 'geodesic'). Calculating that 'straight line' gives you the trajectory.
See: http://en.wikipedia.org/wiki/Geodesic_equation#Affine_geodesics
Thanks for the reply.
Is there something more along the lines of calculating the weight of an object?
If you have a stationary object and a static geometry, the force required to stay in place can be written as [itex]\nabla_{\alpha} u{\alpha}[/itex] where [itex]u^{\alpha}[/itex] is the four-velocity of the object in question.
(I'm not sure if this will be directly helpful to you or not, because I don't know what level of knowledge of the math baackground you have).
This is well defined because its easy to define a co-located "stationary" reference object when you have a static geometry.
You can then measure the acceleration of your test object relative to your rest object, and call this the "weight" of the object.
In a non-static geometry, it becomes difficult if not impossible to find some reference observer to measure the relative acceleration to to measure any sort of traditional "force". What you can do, instead, is measure the tidal force, which is the relative acceleration of two objects a certain distance apart.
If your objects are following geodesics, the relative acceleration (and hence the loal derivative of the force) is given exactly by the geodesic deviation equation
acceleration = [tex]R^{\alpha}{}_{\beta}{\gamma}{\delta}\,\, u^{\beta} u^{\delta} \,\, d^{\gamma}/tex]
Here [itex]u^{\alpha}[/itex] is the four-velocity, as before, and [itex]d^{\alpha}[/itex] is the separation vector.
Unfortunately, while in flat space-time you can integrate the derivative of the force without worrying about the specific path, in curved space-time this integral may become path dependent.
If the objects are NOT following geodesics, there are some interpretational issues which will affect the results of the above calculation. Howeer, it would be premature to go into the details, especially as under normal circumstances the errors are very small. For all practical purposes, if you have an object that's accelerating at modest rates (say less than 10,0000 g's), you won't notice the difference.
That is not trivial but doable if you are willing to make a few simplifications.
1. We assume the Earth (A) is not rotating and is a perfect ball.
2. We assume the mass of the ball (B) is negligible.
Then we can use the Schwarzschild solution (although for a mass the size of the Earth hardly useful as the results will be very close to Newton's solutions), this solution is derived from the field equations and includes the assumption that Newton's law of gravitation is correct at infinity and for c->infinity.
If you are interested how the Schwarzschild solution is derived you can check: http://en.wikipedia.org/wiki/Deriving_the_Schwarzschild_solution
DrGreg said:
There is an equation in GR
[tex]g = - \frac{Gm}{r^2 \sqrt{1 - 2Gm/rc^2}} [/tex]​
However, the r in that equation is not "radius" in the sense of something you could measure with a stationary ruler next to a black hole. In fact you can't measure such a radius, because any ruler that approached the hole would fall to pieces. r is the circumference of an orbiting circle divided by [itex]2 \pi[/itex], which in GR is not the same thing a ruler-measured radius.
Actually proving the formula is no easy thing.
Reference: Woodhouse, N M J (2007), General Relativity, Springer, London, ISBN 978-1-84628-486-1, page 99
Thanks guys. I'm wondering if I describe in words what GR says about weight, comparing it to Newtonian gravity.
The weight of an object = the energy content of that object (it's mass) multiplied by the local spacetime curvature.
Would this be incorrect?
Relevant to my last post, does it make sense to imagine that the field equations define/describe the curvature of spacetime around a gravitational body?
Say we have a gravitational body of a known mass, e.g. the Earth. Could we say that at a place X distance from the center of the body (assuming beyond the surface of the object), there will be a calculated degree of spacetime curvature (also assuming there are no other large bodies to be concerned with)? So the equations would tell us the spacetime curvature at X, and therefore the gravitational acceleration of anything at that distance. Then, putting an object of known mass at that distance, e.g. a 1kg ball, we could predict the gravitational force on that object.
Or is this not how the field equations work?
Anybody?
Well, if you consider any static, spherically symmetric object then the geometry of space - time outside the source would be described by the schwarzchild metric and from that metric one can determine the independent components of the Riemann tensor [itex]R^{\alpha }_{\beta \mu \nu }[/itex] or scalar curvatures like the Ricci scalar or even [itex]R^{\alpha \beta \gamma \delta }R_{\alpha \beta \gamma \delta } = \frac{48M^{2}}{r^{6}}[/itex] and this will give you a scalar curvature at each r for which it is defined but note that this is not giving a curvature for a distance r from the center of the body because for the schwarzchild metric the r coordinate is not the distance from the center of the spherically symmetric, static object (it is not the same r as that in euclidean space). In order to figure out how much an object would "accelerate" for this space - time you would have to form a separation vector that connects the geodesic the particle is traveling on in the schwarzchild space- time to a nearby geodesic and see how the separation vector changes. You can write this as [itex]\frac{D^{2}\xi ^{\alpha }}{D\tau ^{2}} = R^{\alpha }_{\beta \gamma \delta }U^{\beta }U^{\gamma }\xi ^{\delta }[/itex] where [itex]\boldsymbol{\xi }, \mathbf{U}[/itex] are the separation vector and 4 - velocity of the particle respectively and the components of [itex]R^{\alpha }_{\beta \mu \nu }[/itex] would of course come from the schwarzchild metric but remember that this describes gravitational tidal forces.
Spacetime curvature relates to gravitational tides rather than "acceleration". It relates to the rate of change of "gravitational acceleration".
Imaging one object close to the Earth and another object much further away from Jupiter, such that both measure the same local "acceleration due to gravity". The one nearer the Earth would be in a region of greater spacetime curvature, because gravity "changes more rapidly" near the Earth compared with a long way from Jupiter.
Related to General Relativity Gravitation Calculations
1. How is General Relativity used to calculate gravitational forces?
General Relativity is a theory of gravity that describes the relationship between matter and spacetime. It uses the concept of curved spacetime to explain how objects with mass create a gravitational field. This field then causes other objects to experience a force of attraction towards the object with mass.
2. What is the equation for calculating gravitational force in General Relativity?
The equation for calculating gravitational force in General Relativity is F = G * (m1m2 / r^2), where F is the force of gravity, G is the gravitational constant, m1 and m2 are the masses of the two objects, and r is the distance between them.
3. How does the theory of General Relativity differ from Newton's law of gravitation?
Newton's law of gravitation is a classical theory that describes gravity as a force between masses, while General Relativity is a modern theory that explains gravity as a curvature of spacetime. General Relativity also takes into account the effects of acceleration and the bending of light, which are not accounted for in Newton's law.
4. Can General Relativity be used to calculate gravitational forces in extreme conditions, such as near black holes?
Yes, General Relativity is able to accurately predict gravitational forces in extreme conditions. In fact, it was first developed to explain the motion of objects in the vicinity of massive objects like black holes.
5. How does General Relativity impact our understanding of the universe?
General Relativity has greatly impacted our understanding of the universe by providing a comprehensive theory of gravity and explaining phenomena such as the bending of light, the expansion of the universe, and the existence of black holes. It has also been used to make predictions that have been confirmed through observations and experiments, further solidifying its role in shaping our understanding of the universe.
