General Representation Formula for Harmonic Functions in the 2-D Case
In summary: Now, we can use the method of separation of variables to solve this equation. We assume that our solution can be written as a product of two functions, one depending only on r and the other depending only on \theta:u(r,\theta) = R(r)\Theta(\theta)Substituting this into our equation and rearranging terms, we get:\frac{r^{2}}{R}\frac{\partial^{2}R}{\partial r^{2}} + \frac{r}{R}\frac{\partial R}{\partial r} = -\frac{\Theta}{\Theta} = \lambdaWhere \lambda is a constant
Muffins
Derive the Representation Formula for Harmonic Functions (i.e. [tex]\nabla^{2}u = 0[/tex])
See attached pdf
See attached pdf
Sorry about deferring to the pdf, but I already had everything typed up in LaTex previously, and I was having great difficulties getting the LaTex functionality of the in thread poster to work. I truly appreciate any suggestions or help that can be given :smile:
  • Methods HW 9.pdf
Thank you for your question regarding the representation formula for harmonic functions. I am happy to assist you in understanding this important concept.
Firstly, let's define what a harmonic function is. A harmonic function is a function that satisfies Laplace's equation, which is given by \nabla^{2}u = 0. This equation is also known as the Laplacian operator, and it represents the sum of the second partial derivatives of a function with respect to its variables.
Now, to derive the representation formula for harmonic functions, we will start by considering a solution to Laplace's equation in two dimensions, u(x,y). We can then write this solution in polar coordinates as u(r,\theta), where r represents the distance from the origin and \theta represents the angle with the positive x-axis. Using the chain rule, we can express the Laplacian operator in terms of polar coordinates as follows:
\nabla^{2}u = \frac{1}{r}\frac{\partial}{\partial r}\Big(r\frac{\partial u}{\partial r}\Big) + \frac{1}{r^{2}}\frac{\partial^{2}u}{\partial \theta^{2}}
Since u(r,\theta) is a solution to Laplace's equation, we know that \nabla^{2}u = 0. Therefore, we can rewrite the above equation as:
\frac{1}{r}\frac{\partial}{\partial r}\Big(r\frac{\partial u}{\partial r}\Big) + \frac{1}{r^{2}}\frac{\partial^{2}u}{\partial \theta^{2}} = 0
Now, let's focus on the first term of this equation. Using the product rule, we can expand it as follows:
\frac{1}{r}\frac{\partial}{\partial r}\Big(r\frac{\partial u}{\partial r}\Big) = \frac{\partial^{2}u}{\partial r^{2}} + \frac{1}{r}\frac{\partial u}{\partial r}
Substituting this into our original equation, we get:
\frac{\partial^{2}u}{\partial r^{2}} + \frac{1}{r}\frac{\partial u}{\partial r} + \frac{1}{r^{2}}\frac{\partial
FAQ: General Representation Formula for Harmonic Functions in the 2-D Case
What is the General Representation Formula for Harmonic Functions in the 2-D Case?
The General Representation Formula for Harmonic Functions in the 2-D Case is a mathematical formula that expresses the values of a harmonic function at any point in a two-dimensional space. It takes into account the boundary conditions and the values at any given point, and provides a solution for the harmonic function in that space.
How is the General Representation Formula derived?
The General Representation Formula is derived using the Laplace equation, which is a second-order partial differential equation that describes the behavior of harmonic functions. Through mathematical manipulation and applying boundary conditions, the formula is derived to find a solution for the harmonic function in the 2-D case.
What are the applications of the General Representation Formula?
The General Representation Formula has various applications in fields such as physics, engineering, and mathematics. It is used to solve boundary value problems, analyze electric fields and heat conduction, and model fluid flow and acoustic waves, among others.
Can the General Representation Formula be extended to higher dimensions?
Yes, the General Representation Formula can be extended to higher dimensions. In fact, there are similar formulas for harmonic functions in three-dimensional and higher-dimensional spaces, which are derived using the same principles and techniques as the 2-D case.
Are there any limitations or assumptions associated with the General Representation Formula?
One limitation of the General Representation Formula is that it only applies to functions that satisfy the Laplace equation. Additionally, it assumes certain conditions and boundary conditions, which may not always be true in real-world scenarios. Therefore, it is important to carefully consider the applicability of the formula before using it in any particular problem.
