General rule of resolution of optical systems
In summary, according to the Faynman Lectures on physics, the general rule for resolving two different point sources on an optical instrument is that the difference in time for the maximal rays from one source to reach a focused point and its own true image point must exceed one period. This can be expressed as t2-t1 > period. Faynman also states that the distance between the two source points, D, and the angle of the lens opening, θ, can be used to calculate the resolution limit of d exceeding λ/(n sinθ). Additionally, Faynman notes that the angle θ is approximately equal to λ/D, where D is the lens diameter. The chapter in the Faynman lectures where this is discussed
Marketo
According to Faynman Lectures on physics in the chapter of geometrical vol1 ch27, the general rule for the resolution on any optical instrument is this: Two different point sources can be resolved only if one source is focused at such a point that the times for the maximal rays from the other source to reach that point, as compared with its own true image point, differ by more than one period.
and Faynman resume this in the next expression t2-t1 > period
Faynman also says that if D is the distancee between the two soure points and if θ is the angle of the lens opening, the last equation is equivalent to say that d must exceed λ/(n sinθ)
Faynman also says that the angle θ is about λ/D, where D is the lens diameter.
I can't find an explanation of all of this, and it would be write to understand it because I have to talk about telescope. The chapter of Faynman lectures where you can find all of this is attached for this thread
  • Vol 1 Ch 27 - Geometric Optics.pdf
Science news on Phys.org
There really is no single hard-limit formula for the resolution of an optical system, because you have to define what exactly you mean by "resolve". Intensity dip between the images is 50%? 20%? Equal to the RMS noise level? What is the spatial period of the noise? Etc. To characterize an optical system, you can use a modulation transfer function, or a point-spread function, but both characterizations are curves, not single numbers.
Related to General rule of resolution of optical systems
1. What is the general rule of resolution of optical systems?
The general rule of resolution of optical systems is a fundamental principle in optics that explains the ability of an optical system to distinguish between two closely spaced objects. It states that the resolution of an optical system is inversely proportional to the wavelength of light used to view the object and directly proportional to the numerical aperture of the system.
2. How does the general rule of resolution of optical systems affect image quality?
The general rule of resolution of optical systems has a major impact on image quality. It determines the smallest details that can be resolved in an image and the overall sharpness of the image. A higher resolution results in a clearer and more detailed image, while a lower resolution may lead to blurry or distorted images.
3. What factors affect the resolution of an optical system?
Several factors can affect the resolution of an optical system, including the quality of the lenses, the numerical aperture, and the wavelength of light used. Other factors to consider include the distance between the object and the lens, the size of the aperture, and any aberrations in the optical system.
4. How does the numerical aperture impact the resolution of an optical system?
The numerical aperture (NA) is a measure of the light-gathering ability of an optical system. The higher the NA, the smaller the details that can be resolved in an image. This is because a higher NA allows more light to enter the system, resulting in a smaller diffraction spot and a better resolution.
5. Is the general rule of resolution applicable to all types of optical systems?
The general rule of resolution is applicable to most types of optical systems, including microscopes, telescopes, and cameras. However, it may not apply to some specialized systems, such as adaptive optics or super-resolution microscopes, which use advanced techniques to overcome the diffraction limit and achieve higher resolutions.
  • STEM Educators and Teaching
  • Classical Physics
