General solution to linear homogeneous 2nd order ODEs
In summary: If y1 and y2 are orthogonal, and the solutions to the DE form a vector space of dimension 2, then doesn't it follow that any other solution must be a linear sum of...y1*y2?Yes, that's right.
Frank Castle
580
23
Given a linear homogeneous 2nd order ODE of the form $$y''(x)+p(x)y'(x)+q(x)=0$$ the general solution is of the form $$y(x)=c_{1}y_{1}(x)+c_{2}y_{1}(x)$$ where ##c_{1},c_{2}## are arbitrary constants and ##y_{1}(x), y_{2}(x)## are linearly independent basis solutions.
How does one prove that the general solution is given by the above?
substitute the proposed general solution into the DE and see.
[edit] is there a typo in the general solution equation?
Mod note: Now fixed in orig. post...
Frank Castle said:
Given a linear homogeneous 2nd order ODE of the form $$y''(x)+p(x)y'(x)+q(x)=0$$ the general solution is of the form $$y(x)=c_{1}y_{1}(x)+c_{1}y_{1}(x)$$ where ##c_{1},c_{2}## are arbitrary constants and ##y_{1}(x), y_{2}(x)## are linearly independent basis solutions.
One explanation appeals to concepts from linear algebra. The solution space for a first-order, homogeneous differential equation has dimension one, so if a nontrivial solution (i.e., not identically zero) can be found, every solution will be a constant multiple of this solution.
The solution space for a second-order, homogeneous differential equation has dimension two. If you have two linearly independent solutions, then the solution space is spanned by these two functions. That is, the general solution consists of all linear combinations of the two basis functions, exactly as you show in the second equation. If two initial conditions are given, then the constants ##c_1## and ##c_2## can be determined to give a unique solution.
For a third-order, homogeneous differential equation, there need to be three linearly independent basis functions, and so on, for higher-order equations.
Yes, sorry. It should read ##y(x)=c_{1}y_{1}(x)+c_{2}y_{2}(x)##.
The solution space for a second-order, homogeneous differential equation has dimension two. If you have two linearly independent solutions, then the solution space is spanned by these two functions. That is, the general solution consists of all linear combinations of the two basis functions, exactly as you show in the second equation. If two initial conditions are given, then the constants c1c_1 and c2c_2 can be determined to give a unique solution.
That's kind of how I intuitively see it, but I was wondering how one proves it (or is such a proof fiendishly hard)?
I have several DE textbooks, but I don't remember any of them proving that a linear combination of basis functions is the general solution, but then, I haven't looked at these books for quite a while. However, a proof of this wouldn't be "fiendishly hard," I don't believe, and possibly would use a proof by contradiction. If I get a chance later today, I'll see what I can find.
Ok great, I'd much appreciate that.
If you can get hold of a copy of "An introduction to Linear Analysis", Kreider, Kuller, Ostberg, and Perkins, then you can see their partial proof of this in their Theorems 3.2 and 3.3.
Theorem 3.2 states an existence and uniqueness theorem for the solutions of a normal n'th order linear DE, given a set of initial conditions but refers the reader elsewhere for the proof, and Theorem 3.3 relies on this to show that said DE has n l.i. solutions which span the solution space of the DE.
They prove Theorem 3.3 by choosing a set of n initial conditions for which it is easy to show that the corresponding solutions (which exist and are unique by Theorem 3.2) are l.i.
I see I misunderstood:
Given DE: y'' + py' + q = 0
knowing y1 and y2 are independent solutions, then y = Ay1 + By2 is also a solution, for any arbitrary A,B... prove by substitution.
So what you want to prove is that any other solution can be written as a linear sum of two independent solutions, not just that any linear combination is a solution. i.e. is there a y, that is a solution, that cannot be written as a linear sum of y1 and y2?
If y1 and y2 are orthogonal, and the solutions to the DE form a vector space of dimension 2, then doesn't it follow that any other solution must be a linear sum of y1 and y2?
If we want to prove that it does follow - then look up the corresponding proof for a general vector space.
What did I miss?
Yes, this is basically what I want to prove.
This follows if their corresponding Wronskian is non-zero, right? I can see how it must be the case if you consider ##y_{1}## and ##y_{2}## as a basis for a two dimensional vector space, but isn't there some sort of proof without using linear algebra?
I think what I find hard to justify is why the solution space to an ##n##-th order differential equation must be ##n##-dimensional? I can kind of see that if this is the case, then if we can find ##n## linearly independent solutions ##y_{1},\cdots ,y_{n}## (whereby linear independence corresponds to ##W(y_{1},\cdots ,y_{n};x)\neq 0##), then every solution must be a linear combination of these "basis" solutions, but I'm unsure how to prove that this is true?!
Related to General solution to linear homogeneous 2nd order ODEs
1. What is a linear homogeneous 2nd order ODE?
A linear homogeneous 2nd order ODE (ordinary differential equation) is a type of mathematical equation that involves a function and its derivatives. It is called "linear" because the function and its derivatives appear in a linear fashion, and "homogeneous" because all terms in the equation are of the same degree.
2. How do you solve a linear homogeneous 2nd order ODE?
To solve a linear homogeneous 2nd order ODE, you must first identify the coefficients of the function and its derivatives. Then, you can use techniques such as substitution, integration, and solving for constants to find the general solution. This solution will involve two arbitrary constants, which can be determined by applying initial conditions or boundary conditions.
3. What is the general form of the solution to a linear homogeneous 2nd order ODE?
The general form of the solution to a linear homogeneous 2nd order ODE is y(x) = c1y1(x) + c2y2(x), where y1(x) and y2(x) are two linearly independent solutions and c1 and c2 are arbitrary constants. This form can also be written as y(x) = c1e^(λ1x) + c2e^(λ2x), where λ1 and λ2 are the roots of the characteristic equation.
4. What is the characteristic equation in a linear homogeneous 2nd order ODE?
The characteristic equation in a linear homogeneous 2nd order ODE is a polynomial equation that is obtained by setting the coefficients of the function and its derivatives equal to zero. Its roots, denoted as λ1 and λ2, are used to determine the form of the general solution.
5. Can the general solution to a linear homogeneous 2nd order ODE be expressed in terms of elementary functions?
In some cases, the general solution to a linear homogeneous 2nd order ODE can be expressed in terms of elementary functions such as polynomials, exponential functions, and trigonometric functions. However, there are cases where the solution involves special functions such as Bessel functions or hypergeometric functions. In these cases, the solution cannot be expressed in terms of elementary functions.
