Generalized coordinates- scalar product
In summary, the scalar product of the vector (0,1) with itself in plane polar coordinates is r2. The r, θ components of the unit vector in the θ direction can be determined using the same equation, but it is essentially asking for the length of the unit vector, which should be known.
JimKC
a: In plane polar coordinates, find the scalar product of the vector (0,1) with itself.
b: What would be the r, θ components of the unit vector in the θ direction?
Scalar product of 2 vectors = AαgαβBβ
For part a, I used the equation above to determine the scalar product of (0,1) with itself is r2.
Assuming that's correct, I'm really stuck on part b and not sure what to do.
It's pretty much the same as the question "what is the length of a unit vector?". You should know an answer to that.
Likes Orodruin and berkeman
Related to Generalized coordinates- scalar product
What is the concept of generalized coordinates in physics?
In physics, generalized coordinates refer to a set of coordinates that describe the position of a system. Unlike traditional coordinates (such as Cartesian coordinates), generalized coordinates may not be spatial in nature and can include other physical quantities such as angles or momenta.
Why do we use generalized coordinates in physics?
Generalized coordinates are useful in physics because they simplify the description of complex systems. By choosing the appropriate generalized coordinates, we can reduce the number of variables needed to describe a system, making calculations and analyses more efficient.
What is the scalar product of two vectors in terms of generalized coordinates?
In terms of generalized coordinates, the scalar product of two vectors is defined as the sum of the products of the components of the vectors along each of the generalized coordinates. This can also be expressed as the dot product between the two vectors.
How is the scalar product related to the concept of work in physics?
The scalar product is closely related to the concept of work in physics. In fact, work can be calculated as the scalar product of a force vector and a displacement vector. This means that the scalar product gives us a measure of the component of a force that is parallel to a given displacement, which is the work done by that force.
Can the scalar product be used to determine the angle between two vectors in generalized coordinates?
Yes, the scalar product can be used to determine the angle between two vectors in generalized coordinates. The angle between two vectors can be calculated using the inverse cosine function of the scalar product divided by the product of the magnitudes of the two vectors. This is also known as the dot product formula for calculating the angle between two vectors.
  • Linear and Abstract Algebra
