Generalized version of work-energy theorem
In summary, the conversation discusses the work-energy theorem and its application to rigid and non-rigid bodies, as well as conservative and non-conservative forces. The equation provided by Doc Al uses center of mass quantities and does not take into account changes in other forms of energy, such as potential energy or heat energy. It is important to note that this equation should not be confused with the more general conservation of energy. It is also noted that all forces contribute to the change in kinetic energy of the center of mass, and external forces can also change the energy of a system.
donaldparida
146
I know that for rigid bodies only the work-energy theorem states that the net work done on the body equals the change in kinetic energy of the body since a rigid body has no internal degrees of freedom and hence no other forms of energy such as potential energy. Is there a most generalized form of work energy theorem that is valid for rigid as well as non rigid bodies and for conservative as well as non-conservative force?
This might not be what you're looking for, but it applies to rigid or non-rigid bodies, since it deals with center of mass quantities:
$$F_{net}\Delta x_{cm}=\Delta (\frac{1}{2}m v_{cm}^2)$$
No
We can apply work energy theorem for a rigid body or a point particle substituting the body(center of mass) in former case(applying work energy theorem for rigid body) we may have terms like rational kinetic energy,...
But in the later one(applying work energy theorem for centre of mass of the rigid body) we may have terms for work done due to those forces which did zero work on the rigid body(due to no movement of point of contact)
Willy nilly we get the same result
It all matters on what you choose your system to be
What might be potential energy in one case can be work done by external force in another case
Shreyas Samudra said:
No
Yes! (The theorem is a consequence of Newton's 2nd law.)
One can certainly apply conservation of energy, but I thought the question was asking for something different.
Exactly! Those terms have the appearance of work, but do not reflect actual work done (in the first law of thermo sense). Nonetheless, the theorem is valid.
Likes person_random_normal
Hey
What happened??
@Doc Al, I think that your equation will work out for rigid and non-rigid objects but why is there no account of change in other forms of energy(potential energy, heat energy) in the equation? Another question:Does Fnet include the non conservative forces as well or only the conservative forces(is Fnet the resultant of the net conservative force and the net non-conservative force)?
Don't confuse this equation with the much more general conservation of energy.
Fnet includes all forces acting on the body, whether conservative or not.
Could you please elaborate.
Video 1 (work energy theorem-18:00 to the end)
Video 2 (work energy theorem-full video)
He' a great prof. (simply awesome)
BUT YOU HAVE TO UNDERSTAND INDIAN ACCENT !
Sure. The equation I gave is derived from Newton's 2nd law, using the properties of the center of mass. The left hand side looks like a work term, but is not. (It's sometimes called center of mass work or pseudowork.) The work terms used in conservation of energy equations require the forces to be combined with the displacement of their point of application, not the displacement of the center of mass. And conservation equations can have all sorts of internal energy quantities.
So these equalities are valid for point particles, rigid bodies and non-rigid bodies, Right?
ΔK.E. = Wnet = Fnet . dcentre of mass = (Fnet conservative + Fnet non-conservative + Fnet external) . dcentre of mass = Wnet conservative + Wnet non-conservative + Wnet external
And the potential energy is included in Wnet conservative. Correct?But is there any proof that Wnet conservative=-ΔP.E.?
Also i could not understand one thing: do conservative forces change the K.E. and non-conservative forces change the P.E. or the opposite or do both the types of forces can change both the types of energy and what type of energy can external forces change.
The center of mass equation that I gave is valid for all of these.
Careful about setting the center of mass "work" term equal to the total change in energy. Don't confuse that equation with the more general conservation of energy.
All forces contribute to the change in the KE of the center of mass.
Here's what's tricky, and where the center of mass equation is useful. Imagine jumping into the air. Your KE obviously has changed, despite no external work being done on you. The center of mass equation still holds.
Likes donaldparida
@Doc Al , I know that the work done by conservative forces is independent of the path taken, i.e., the work done by conservative forces in moving an object from an initial point to a particular final point is the same for different paths taken. Thus the potential energy of the object at the particular fixed point is same for different paths taken to reach the particular final point from the initial point and so it is wise and useful to use the concept of potential energy in case of the work done by conservative forces.
In case of non-conservative forces some difficulty arises because non-conservatives forces are path dependent. The work done by non-conservative forces is dependent on the path taken,i.e., the work done by non-conservative forces in moving an object from an initial point to a particular final point is different for different paths taken. Thus the potential energy of the object at the particular final point is different for different paths taken to reach the particular final point from the initial point and so it is not wise and useful to use of the concept of potential energy in case of the work done by non-conservative forces. Also mechanical energy is conserved in case of conservative forces while in case of non-conservative forces mechanical energy is not conserved. So far correct.Right?
Now i recently understood the reason why W net conservative = -ΔP.E.(which had been troubling me for long). The work done by conservative forces have been defined like this, so that the law of conservation of mechanical energy is complied to when no non-conservatives are acting on the body(In which case the law of conservation of mechanical is not complied to).Correct?
Also isn't it correct that both conservative forces and non-conservatives increase the potential energy of the body(although the concept of potential energy is not used for non-conservative forces) but we let the conservative forces account for all the changes in potential energy?
So in conclusion, All the types of forces(conservative, non-conservative and external forces) increase both the kinetic and potential energy of the body but we let the only the conservative force account for all the change in the potential energy.Right?
Potential energy is only defined for conservative forces.
True.
Not really. A change in potential energy can only involve conservative forces. If you think otherwise, perhaps you can give an example of what you mean.
For example:When a non-conservative force moves an object from one point to another point there is indeed an energy change of the body and do you think of this:
And what do you think of this:The work done by conservative forces have been defined like this, so that the law of conservation of mechanical energy is complied to when no non-conservatives are acting on the body(In which case the law of conservation of mechanical is not complied to)
Right. But if there is any change in PE it is due to the action of conservative forces. (By definition, essentially.)
Sounds OK to me.
@Doc Al,If non-conservative forces do not change potential energy then why is it equal to ΔM.E.(ΔK.E.+ΔP.E.)?
@Doc Al ,In addition to the above question can you also tell that whether the work done by forces on the point of application equal to the work done on the center of mass of a body(Can we substitute the work done by the forces on the point of application by the center of mass)?
Perhaps we're getting lost in semantics. Can a non-conservative force change the the PE of a system? Sure. But there must be conservative forces acting--else there would be no PE at all.
Likes donaldparida
No, definitely not. The work done by forces on the point of application is the "real" work. A force can produce center of mass "work" yet do zero work against the point of contact. (Consider the example of jumping that I gave before.) And you can also have forces that do real work, yet no center of mass "work".
Likes donaldparida
Oh now i got it!Thank you:woot:
@Doc Al , Is it correct that for rigid bodies only, if a force act on it the work done on the center of mass is equal to the work done on the point of application of force?
Also i do not see how we can apply work energy theorem for non-rigid bodies since in general the work done on the center of mass is not equal to the work done on the point of application of force.
Also can a conservative force change the potential energy of a rigid body when it is lifted up?
One could come up with contrived examples of non-rigid bodies for which a particular force just happens to do "real work" equal to the "center of mass" work. This would require that the movement of the point of application in the direction of the applied force was equal to the movement of the center of mass in the direction of the applied force. [For example, one might hoist a bucket of swirling water from a well]
You can locate the center of mass of a non-rigid body. You can apply a force to a non-rigid body. You can determine how much speed the center of mass will gain or lose based on the force applied and the distance the center of mass moves while the force is applied.
It would be more correct to say that the potential energy of a rigid (or non-rigid) body is embodied by the conservative force. They are two ways of looking at the same thing. The conservative force acts to drain energy from the body as it is lifted up and acts to provide energy as it is allowed to fall back down. We look at the energy that is provided on the way back down and think of it as potential energy that was already present when the object was at its high point.
Likes donaldparida and Doc Al
No, not even for rigid bodies is that true in general. Imagine an extended body, such as a rod. You can push the end of the rod, doing work on it, but some of that work will go into rotational energy, not center of mass energy.
@jbriggs444 gave an excellent response to your question; I encourage you to study it.
Related to Generalized version of work-energy theorem
What is the generalized version of the work-energy theorem?
The generalized version of the work-energy theorem is a fundamental principle in physics that relates the work done on an object to its change in kinetic energy. It takes into account not only the work done by external forces, but also the work done by non-conservative forces such as friction or air resistance.
What is the formula for the generalized version of the work-energy theorem?
The formula for the generalized version of the work-energy theorem is W = ΔK + ΔU, where W represents the total work done on the object, ΔK is the change in kinetic energy, and ΔU is the change in potential energy.
How is the generalized version of the work-energy theorem different from the basic version?
The basic version of the work-energy theorem only takes into account the work done by external forces, while the generalized version takes into account both external and non-conservative forces. This makes it a more comprehensive and accurate representation of the relationship between work and energy.
What is an example of applying the generalized version of the work-energy theorem?
An example of applying the generalized version of the work-energy theorem is calculating the work done on a car as it moves up a hill. In this scenario, the work done by the car's engine is offset by the work done by friction and air resistance, resulting in a change in the car's kinetic and potential energy.
Why is the generalized version of the work-energy theorem important in physics?
The generalized version of the work-energy theorem is important in physics because it is a fundamental principle that helps us understand the relationship between work and energy in various scenarios. It is applicable in many different fields of physics, including mechanics, thermodynamics, and electromagnetism.
  • Mechanics
