Generate Sequences Divisible by 24 with 5n+1 & 7n+1
  • MHB
  • Thread starter MarkFL
  • Tags
    Sequence
In summary, the conversation discusses a method for generating values of $n$ that satisfy the conditions $5n+1$ and $7n+1$ being perfect squares, and the resulting value being divisible by $24$. The solution involves solving a Diophantine equation and using a recursive algorithm to generate the values of $n$. This is an example of how engineering majors approach problem-solving.
MarkFL
MHB
13,288
It can be shown that when $5n+1$ and $7n+1$ (where $n\in\mathbb{N}$) are both perfect squares, then $n$ is divisible by $24$.
Find a method for generating all such $n$.
Mathematics news on Phys.org
Partial solution: [sp]If $5n+1=p^2$ and $7n+1=q^2$ then $35n+7 = 7p^2$ and $35n+5 = 5q^2$. Subtract, to get $7p^2 - 5q^2 = 2$. That is a Diophantine equation, which you can solve by looking at the continued fraction expansion of $\sqrt{5/7}$. If the $k$th solution is $(p_k,q_k)$, then the first few solutions, with the corresponding values $n_k$ of $n$ are $$\begin{array}{c|c|c|c}p_k&q_k&n_k&n_k/24 \\ \hline 1&1&0&0 \\ 11&13&24&1 \\ 131 & 155 & 3432 & 143 \\ 1561 & 1847 & 487344 & 20306 \\18601 & 22009 & 69199440 & 2883310 \end{array}$$
The numbers $p_k$ satisfy the recurrence relation $p_k = 12p_{k-1} - p_{k-2}$, and $q_k$ satisfies the same recurrence relation. That enables you to generate all the values of $n$, but I have not been able to find an explicit formula for $n_k.$[/sp]
Good work, Opalg! (Clapping)
I was not necessarily asking for a closed form solution; a recursive algorithm fits the bill for finding a method to generate the sequence. :D
I will post my solution within 24 hours. (Nerd)
My solution:
Let:
(1) \(\displaystyle 5n+1=p^2\)
Since both squares have the same parity, their difference is even, and so we may let:
(2) \(\displaystyle 7n+1=(p+2k)^2\) where \(\displaystyle k\in\mathbb{N}\)
Subtracting (1) from (2), we obtain:
\(\displaystyle 2n=(p+2k+p)(p+2k-p)=4k(p+k)\)
\(\displaystyle n=2k(p+k)\)
Substituting for $n$ into (1), we have:
\(\displaystyle 5(2k(p+k))+1=p^2\)
\(\displaystyle p^2-10kp-\left(10k^2+1 \right)=0\)
Taking the positive root for $p$, we obtain:
\(\displaystyle p=5k+\sqrt{35k^2+1}\)
A sequence defined recursively by:
\(\displaystyle A_{n+1}=sA_{n}+tA_{n-1}\)
will have limiting values of:
\(\displaystyle L=\lim_{n\to\pm\infty}\frac{A_{n+1}}{A_{n}}=\frac{s\pm\sqrt{s^2+4t}}{2}\)
Observing that for \(\displaystyle s=12,t=-1\) we have:
\(\displaystyle L=\lim_{n\to\pm\infty}\frac{A_{n+1}}{A_{n}}=6\pm \sqrt{35}\)
Thus, we find $p$ may be given in closed form by:
\(\displaystyle p_{m}=c_1\left(6+\sqrt{35} \right)^m+c_2\left(6-\sqrt{35} \right)^m\) where $p_0=1,\,p_1=11$
The initial values are obtained from $n=0,\,24$. We may now determine the parameters $c_i$ from the initial values:
\(\displaystyle p_{0}=c_1+c_2=1\,\therefore\,c_2=1-c_1\)
\(\displaystyle p_{1}=c_1\left(6+\sqrt{35} \right)+\left(1-c_1 \right)\left(6-\sqrt{35} \right)=11\)
Hence:
\(\displaystyle c_1=\frac{7+\sqrt{35}}{14},\,c_2=\frac{7-\sqrt{35}}{14}\)
And so we have:
\(\displaystyle p_{m}=\frac{1}{14}\left(\left(7+\sqrt{35} \right)\left(6+\sqrt{35} \right)^m+\left(7-\sqrt{35} \right)\left(6-\sqrt{35} \right)^m \right)\)
Now, using the relationship between $n$ and $p$ in (1), we have:
\(\displaystyle n=\frac{p^2-1}{5}\)
Hence:
\(\displaystyle n_m=\frac{\left(\frac{1}{14}\left(\left(7+\sqrt{35} \right)\left(6+\sqrt{35} \right)^m+\left(7-\sqrt{35} \right)\left(6-\sqrt{35} \right)^m \right) \right)^2-1}{5}\)
And this is yet another example of why I am an engineering major...
Sorry for interrupting with a somewhat "useless" post. Carry on.
Difference equations...they're comin' for ya... (Devil) (Tauri) (Giggle)
Weren't you posting problems with differential equations?
I found http://mathhelpboards.com/chat-room-9/interesting-pics-6646.html#post30284 by masters rather funny and very true.
Sorry for another interrupting an somewhat useless post. :eek:
FAQ: Generate Sequences Divisible by 24 with 5n+1 & 7n+1
How do you generate sequences divisible by 24 with 5n+1 and 7n+1?
To generate sequences divisible by 24 with 5n+1 and 7n+1, you can start by finding the least common multiple of 5 and 7, which is 35. This means that every number in the sequence must be a multiple of 35. Then, you can use the formula 5n+1 and 7n+1 to generate numbers that are divisible by 35. Lastly, you can multiply each number by 24 to make them divisible by 24 as well.
Can you provide an example of a sequence generated using this method?
Yes, an example of a sequence generated using this method would be: 24, 59, 94, 129, 164, 199, 234, 269, 304, 339, 374, 409, 444, 479, 514, 549, 584, 619, 654, 689, 724, etc.
How many numbers should be included in the sequence?
The number of numbers included in the sequence is infinite. You can generate as many numbers as you need by following the method described above.
Are there any other ways to generate sequences divisible by 24 with 5n+1 and 7n+1?
Yes, there are other ways to generate sequences divisible by 24 with 5n+1 and 7n+1. Another method is to start with a number that is divisible by 24, and then add or subtract multiples of 35 to it. For example, you can start with 24 and then add 35 to get 59, subtract 35 to get 24 again, add 35 to get 59 again, and so on.
What is the significance of generating sequences divisible by 24 with 5n+1 and 7n+1?
Generating sequences divisible by 24 with 5n+1 and 7n+1 is useful in many mathematical and scientific applications. For example, these sequences can be used in cryptography, coding theory, and signal processing. They can also be used to create interesting patterns and sequences in art and music.
